boler 1700 window seals - Fiberglass RV
Old 07-17-2020, 09:27 PM   #1
Trailer: Boler 1700
im looking for 1977 boler 1700 window seals and gaskets.
i found this page https://www.fiberglassrv.com/forums/...als-64812.html
but most of parts numbers are can not find.
please tell me where can i find.
thank you
Takviator is offline   Reply With Quote
Old 07-19-2020, 10:35 AM   #2
TN
I found thee glass glazing bead at Pelland the Part number is H009-344-19.
You can probably get some of the other rubber there as well.
https://www.pellandent.com/RV-Window-Seal
Eric Frye is offline   Reply With Quote
Old 07-19-2020, 07:20 PM   #3
Trailer: Boler 1700
thank you for your help.
Old 07-20-2020, 01:01 PM   #4
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Try Vintage Trailer Gaskets:
https://www.vintagetrailergaskets.com/
Alex Adams is online now   Reply With Quote
Old 07-20-2020, 01:22 PM   #5
Trailer: Boler 1700
thank you Alex,
i try it from them. they do not really have same one. i am searching around but can not really found. I guess have to get some thing fit...
Old 07-20-2020, 01:54 PM   #6
Alex Adams's Avatar
New Hampshire
So in that case, assuming you have the old seals and can make out their shapes, I would suggest order a sample pack. I know Vintage Trailer supply can do that. Just select one of everything! Don't assume you won't need it. I did and kicked myself for spending an extra shipping fee to get the rest I didn't order. Vintage trailer supply is at:
https://www.vintagetrailersupply.com/
Is it possible the previous owner replaced windows? I thought the old Bolers used standard Hehr Jalousie windows and standard front and rear fixed windows. If you have the really small oval crank windows in the door or on a wall, I know Vintage Trailer Parts has all of the seals since I just redid one of mine.
Old 07-20-2020, 04:00 PM   #7
Trailer: Boler 1700
I ordered the sample pack from pelland enterprises ($4 in 2017) and all-rite (free), in addition to vintage trailer gaskets. Very good point to request any additional samples you think might work when you request the standard sample pack.
We ended up just relaced the glazing bead on all the windows. We used 1/8" glass glazing bead in black from Pelland (H009-344-19 in 2017).
We're working on the little awning window for the bathroom now. Should know at the end of the week if we like the seals we ordered.
The glass for our windows were mounted in the frame with butyl, on a few of the windows it was toast and we had to reset the glass in the frame.
Lisa in Michigan is offline   Reply With Quote
Old 07-20-2020, 04:50 PM   #8
John in Michigan's Avatar
Trailer: 1979 Boler 1700
To add to what Lisa posted above, we purchased and installed 70 feet of 1/8" glass glazing bead in black (H009-344-19).
Also, we got samples of the Hehr top seal (009-482) from two companies. The Hehr top seal is the very wide horizontal seal inserted at the top of each of the two jalousie windows in our rear gaucho Boler 17. About 7 feet is needed for the two windows. After evaluating the fit of these samples, we haven't decided whether to order it. One supplier only had it in brown, so that wouldn't work. The other supplier's sample didn't fit very well.
Old 07-31-2020, 07:06 PM   #9
Trailer: Boler 1700
The hehr standard glass seal from Vintage trailer supply worked fine for the awning window in the bathroom of the boler 17 (hehr part number 09-111/ Vintage trailer supply VTS-195). We also needed to replace the nylon friction pad (VTS-348) for the awning window - the middle part of ours had worn out. We also used Vintage trailer supply's swivel handle for the jalousie and awning windows.
The hehr backframe gasket was out of stock at vintage trailer supply when we ordered (it's back now) so we ordered from vintage trailer gaskets. Unforunately it got stuck in the post office in the City of Industry, CA for over a week, so haven't tried that yet
by the way, the number on our awning window is 0377 h (with a box around it) C
Old 09-12-2020, 10:15 AM   #10
Trailer: Boler 1700
I got top seal for jalousie window from vintage trailer supply.
https://www.vintagetrailersupply.com...cid=91k4_baci5
i got information from boler.ca but thie seal does not fit. to fit i think need some caulking to glue on i guess.
i need look for some thing else now.
Old 03-31-2021, 05:48 PM   #11
Trailer: Boler 13'
How many feet did you order if you replaced for all windows? Was this one a 17' model?
scamp53 is offline   Reply With Quote
boler
Boler 1700 Window Seals stperic Modifications, Alterations and Updates 12 06-21-2021 08:04 PM
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
boler Side window - Restoring (need List of Seals and where to order) idiotsniff Modifications, Alterations and Updates 20 01-14-2012 09:43 PM
Boler Jalousie dinette window seals rhkirkham Problem Solving | Owners Helping Owners 6 09-28-2011 07:32 AM
Boler Jalousie window seals 67dodge Problem Solving | Owners Helping Owners 8 03-26-2011 02:18 PM
