If true how do you get a battery operated fluorescent light to work?
Battery-operated fluorescents certainly work (I have two), as does the 12V-powered ThinLite fluorescent which I mounted in my
Boler, which has no separate "ground" connection. The compact fluorescents (CFLs) that are screwed into lamps in place of regular bulbs also have no ground connection.
There are a few different starting methods for fluorescent
lights, and one of them requires a ground plane near the tube (a function which apparently can be performed by a human body); if that's the one which Des's fixture uses, the instruction makes sense, but it doesn't apply to all designs. I would be surprised if a modern fixture requires the grounding, but a 30-year-old fixture is a different matter.
