Boler front window rock cover - Fiberglass RV
Old 04-16-2021, 06:36 AM   #1
Nova Scotia
I have a 1975 boler with the original rock cover for the front window. The rubber "gasket" that goes around the outside has been painted and looks really bad.Any idea where I can pick up a replacement, or what it's actually called?
wood turner is offline   Reply With Quote
Old 04-16-2021, 01:38 PM   #2
steve67's Avatar
Trailer: '79 Boler
on Ontario
This is place I've gotten many things for my Boler. Section K has a bunch of rubber shapes/names. This might help.
https://spaenaur.com/download/
steve67 is online now   Reply With Quote
Old 04-17-2021, 05:50 AM   #3
Nova Scotia
thanks
Old 04-17-2021, 10:33 PM   #4
Borden's Avatar
Name: Borden and Carole
Spanair also sells Stanley's waterproof closed end marine rivets.
Our postage stamp in heaven.
Old 04-17-2021, 10:35 PM   #5
Borden's Avatar
Originally Posted by wood turner View Post
thanks
What size is your Boler?
Old 04-18-2021, 06:39 AM   #6
Nova Scotia
It's a b 1300 so it's 13'
We are reupholstering the cushions as the original ones had gone moldy. It sat closed up in a yard for 5 years unused. I'm also redoing all the woodwork in it.
The flooring has been removed and the first really good cleaning has happened.
Old 04-18-2021, 08:31 AM   #7
Borden's Avatar
fixer upper
Spaenaur is a good source for rivets the above was spelling error due to my using cell phone to send it. We are still in process of replacing rivets with closed end Stanley marine rivets. They can be purchased in boxes of 100 pieces. Every original rivet leaked to different degrees when we got our trailer.
Our trailer has had cushions recovered as well with thicker 4" foam instead of original foam for better sleeping.
Took out all cupboards except fridge frame structure to rebuild and repair them.
The original floor was linoleum that was not glued down but floated on the wood subfloor and ran up wall about 1.5" and then frames put on top and screwed down to allow for trailer flex.
The frames where riveted to the fiberglass with tabs that are screwed to frames of cupboards as the boler can not support its body without the frames. The repairs to frames and improved waterproof aluminum closed end type of rivets, stainless steel screws for replacements have all made it stronger and dryer.
We had time to fix ours as it was usable as purchased; after we replaced the tires with new STr tires (Special Trailer Radial) and had the wrong type of tires but was in a trailer park so they did not need correct tires. We have enjoyed our 1978 boler since 8-1-2010 our friends sold it to us they had started its restoration. With new cushions and drapes, fixed brakes etc. prior to putting it up for sale. The furnace never worked and became a priority fix. We have done a lot of fixing over the years wish had done more progress pictures and posted them.
Will be nice to see pictures of your finished product but it is a good idea to take progress pictures of your rebuild. All of us in the group have learned the hard way at times but it was worth the effort.
Old 04-20-2021, 10:01 PM   #8
Trailer: Boler 1300
Not sure if your gravel guard trim is similar to what I had but I picked some up from amazon at the link below and did the trick for mine.
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
bobdobqb is offline   Reply With Quote
boler
Boler front window rock guard install RogerH Problem Solving | Owners Helping Owners 15 01-29-2024 11:37 AM
Amerigo rock guard/window cover... eda239 Modifications, Alterations and Updates 20 07-13-2014 10:09 PM
Boler - Front window rock guard/shade lift shocks modification idiotsniff Modifications, Alterations and Updates 22 06-21-2014 04:45 PM
Making front window rock shield MyronL Modifications, Alterations and Updates 9 02-01-2006 07:08 AM
Burro Front Window Awning & Rock Shield Legacy Posts Problem Solving | Owners Helping Owners 3 07-25-2003 05:38 PM
