Boler sink won't drain - Fiberglass RV
Old 11-26-2016, 09:44 AM   #1
Trailer: Boler 13 ft
Do others have this problem with thier sinks that use the simple single hose drain?
Being a plumber I know there is a need of a vent for a sink to drain properly but was wondering if anyone has done this in a way that looks good on a FG unit.
I don't have room for one of those pop-vents under sink in the 1300 due to the converter and furnace.
Any good looking ways to handle this probelm
Old 11-26-2016, 12:55 PM   #2
Borrego Dave's Avatar
Gerry, seems to me someone else had the same problem and found the tube was kinked pretty bad.
Old 11-26-2016, 03:54 PM   #3
No kink in tube but I do remember that one of the pop-up's that the campground, I worked at, had the same problem and I had to intall a tee in the drain line and I ran a hose up the outside of the tent under the flap to let air into the line and it worked.
It worked but not a very handsom fix...
Maybe some rigid CPVC tube running up the outside of the camper somehow would work.
I hesitate to have an open vent under cabinet if I run the hose into the sewer hook up in campground because of the sewer gas and odor.
Old 11-26-2016, 04:26 PM   #4
floyd's Avatar
Having had about every sink configuration, I have yet to see a drain problem which wasn't due to a kink or an obstruction.
If you have a gray tank,see that it is vented. The ones which drain to the outside into a closed container must also have a vent in the container.
no other vent in the system is needed.
Old 11-27-2016, 06:15 AM   #5
hmmm maybe I'm to fussy and just have to wait the 15 minutes for my sink to drain?
Old 11-27-2016, 08:43 AM   #6
Ah ha...I just got in and after adding a tee to the outside where the trapless hose comes out of the wall and a stand pipe up a bit above the rim of the sink level...it went down like a charm....
Thanks for all the help but now I want to make it look good by doing it all up with some rigid CPVC going into the Tee and out into the hose that goes into the sewer.
Old 11-27-2016, 03:02 PM   #7
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
You only need a vent in the line if at some point in the line the liquid has to run uphill i.e. a trap or a valley in the line. As long as the entire run is down hill it will drain fine. Many years ago an old plumber told me ' you only need to know two things to be a plumber - water will not run uphill and payday is Friday'.
Old 11-27-2016, 05:49 PM   #8
Trailer: 13 ft Scamp
And also coming from a family if plumbers
" it aint all water"
boler
Sink drain valve MyronL Modifications, Alterations and Updates 31 07-10-2019 01:22 AM
Scamp/Hehr door window won't drain? dylanear Problem Solving | Owners Helping Owners 7 04-05-2013 12:56 PM
Sink Faucet and Drain in 2006 Trillium & etc Nichole Adams Plumbing | Systems and Fixtures 9 09-08-2009 10:08 PM
My team won! My team won! Gina D. General Chat 7 02-02-2009 07:41 AM
WE WON!!! WE WON!!! Summer&Brad B. General Chat 19 12-12-2005 08:35 AM
