Bug and tar removal - Fiberglass RV
Old 02-12-2018, 05:01 PM   #1
Trailer: 2015 Escape
Bug and tar removal
Any suggestions about what to use for removing bugs and tar? Obviously has to wait until spring since it was 0 here this morning. Thanks
Old 02-12-2018, 05:24 PM   #2
Trailer: 2009 Escape 17B
Turtle Wax Bug 'N' Tar.
Old 02-12-2018, 05:25 PM   #3
Plus elbow grease. Right?
Old 02-12-2018, 05:33 PM   #4
RV Doctor's Avatar
Iím sure some will criticize but Unleaded Gas is GREAT!
2017 Bigfoot 25B25FB
2017 F-150 2.7 EB
Full Time RV Living
RV Doctor is offline   Reply With Quote
Old 02-12-2018, 06:17 PM   #5
+1.. I found it works even better than Acetone.
Old 02-12-2018, 07:03 PM   #6
WD-40 for small spots. Follow up with acetone to get the WD-40 residue off the gel cote.
Old 02-12-2018, 07:05 PM   #7
Bugs and a large amount of tar. Found myself on a street with fresh tar. I drove very slowly until off it. No way to avoid.
Old 02-12-2018, 07:13 PM   #8
John in Santa Cruz's Avatar
Mid Left Coast
I use WD40, it takes most bugs and tar spots right off. In fact, this is really about all WD40 is good for. Then I wipe with a bit of isopropyl alcohol on a clean rag to remove any oily spot left behind by the WD40. If I need to do this over a big enough area, I'll probably follow up with a quick/light waxing with Meguiars marine cleaner/wax.
Old 02-12-2018, 07:25 PM   #9
Nope. That would be Bug 'N' Tar 'N' Sap.
Old 02-12-2018, 08:10 PM   #10
Oh. pine tree sap.. the worst, right!? Multiple applications of isopropyl alcohol mostly works, followed by a buffing wax.. but even that is not a great solution. I hate pine tree sap!
Old 02-12-2018, 08:25 PM   #11
Carl Pa's Avatar
I use a little dab of mineral oil.
Carl Pa is offline   Reply With Quote
Old 02-12-2018, 08:45 PM   #12
bug juice
hot water and soap elbow grease. work work work!!!
bob
Old 02-12-2018, 10:08 PM   #13
mszabo's Avatar
Dollar Store
Awesome cleaner $1.00 cleans everything!
Old 02-13-2018, 12:23 AM   #14
Andrew Morris's Avatar
Trailer: Scamp 16'
Bounce sheets (dryer sheets). Soak a few in some water and use them to scrub off bugs, etc. They have just the right amount of abrasive, without scratching the gelcoat, and something about the fabric softener in them that helps with the bug removal. I always carry a few in the trailer
Andrew & Allison
Andrew Morris is offline   Reply With Quote
Old 02-13-2018, 06:44 AM   #15
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I would not criticize. I have used lighter fluid, followed by an application of Meguierís Marine Wax.
For pine sap, I have used hand sanitizer. It is, of course, mostly alcohol, but as a gel, it pretty much stays put.
Old 02-13-2018, 10:12 AM   #16
Trailer: U-Haul 1986 -- got it 7/2013
Virginia
For bugs, soapy water, or Windex (the "no-run" kind); the Dollar-Store version works as well as anything else. For tar, kerosene. Wipe it on, let it stand a while, wipe it off. Followed by a little alcohol. I wouldn't use acetone because that can attack the gel-coat. For pine sap, that alcohol-based hand-cleaning gel works pretty well, but it's going to be slow, esp. if the pine sap has picked up some dirt/dust/pollution.
Someone suggested "Pine-Sol" (or Dollar-Store equivalent) for pine sap; I'll have to try it; my house is surrounded by old, tall pines.
Pete Hein is offline   Reply With Quote
Old 02-13-2018, 10:18 AM   #17
RV Doctor's Avatar
Normally for sap will use Methyl Hydrate. It works awesome. I canít get it down here in the US though. The US has Denatured Alcohol. Doesnít work nearly as well to me. Apparently Methyl Hydrate is an ingredient of Crystal Meth so stores donít carry anymore. This isnít my story - From the Home Depot Paint Dept manager.
2017 F-150 2.7 EB
Full Time RV Living
Old 02-13-2018, 10:23 AM   #18
Trailer: Oliver
I remember using Aldolph's meat tenderizer for the leading edge of a Cessna 172 wing and cowling. Worked great.
skalywag is offline   Reply With Quote
Old 02-13-2018, 10:29 AM   #19
Virginia
Methyl Hydrate is the same as Methanol, also called Wood Alcohol. Used to be able to get it in paint stores here in the US, don't know if it's available any more.
Denatured alcohol - there are probably 100 different kinds of denatured alcohol; they're all ethanol (drinking alcohol) that's been treated with something to make it toxic or unpalatable. (This is because the gov't taxes ethanol; the tax would make it too expensive to use as an industrial solvent, but the tax doesn't apply to denatured alcohol.)
The commonest denatured alcohol contains about 4 % methanol, enough to make it poisonous and also to taste awful. Also called "meths" or "methylated spirit".
I'm not surprised that denatured alcohol doesn't do as good a job as pure methanol/methyl hydrate; it's just not as effective a solvent. (Something to do with the size of the molecule, I think.)
As I write this, I'm looking out the window at my Egg, which has gotten very filthy over the Winter. I think I'll be finding out first-hand which of these treatments works best, before too long.
Old 02-13-2018, 10:42 AM   #20
Originally Posted by Pete Hein View Post
... I wouldn't use acetone because that can attack the gel-coat....
Maybe if left on it for a long time, but it is commonly used on gel-coat for the more difficult cleaning jobs. Very common in the marine maintenance world. Still, for bugs and tar I would agree there are safer and healthier options.
Roofing Tar? Really? cannibal53 Problem Solving | Owners Helping Owners 16 01-01-2013 09:53 PM
Want "tar tar" sauce with that? glamourpets Towing, Hitching, Axles and Running Gear 4 10-14-2012 05:15 PM
Tar on Scamp russelld Care and Feeding of Molded Fiberglass Trailers 9 06-12-2012 05:11 PM
Anyone know what to use to remove black tar from roof? Tim Wood Problem Solving | Owners Helping Owners 12 10-31-2008 09:06 AM
Removing road tar and other stuff ted saxton Care and Feeding of Molded Fiberglass Trailers 6 03-28-2008 10:37 PM
