Butyl tape to fix belly band seal. - Fiberglass RV
Old 07-08-2020, 03:51 PM   #1
Trailer: 1975 Ventura
Yukon
Before I go buy fibreglass and fill it in, has anyone used to butyl tape to reseal the belly band? I assume I would see some posts on this if it was a good idea.
sonny75 is offline   Reply With Quote
Old 07-09-2020, 11:48 AM   #2
Trailer: 1993 CASITA 16SD
If it's not leaking I wouldn't seal it. My Casita's belly band is simply attached with small pop rivets and nothing underneath.
CASITA BANANA is offline   Reply With Quote
Old 07-09-2020, 01:20 PM   #3
Yukon
Unfortunately it leaks a lot.
Old 07-09-2020, 02:51 PM   #4
sokhapkin's Avatar
SW Florida
Why do you think that the problem is in the belly band, but not in the nearby to the leak window?
Sergey
www.callwithus.com
Old 07-09-2020, 03:56 PM   #5
Yukon
I ran the garden hose on the belly band. It came in pretty fast
Old 07-10-2020, 07:24 AM   #6
Joe MacDonald's Avatar
If the belly band is like the one on a trillium, the rivets holding it on, are attached to steel plates that were put in place when the trailer was molded, over time water travels in, and rots out the metal, if that is the case, you may not be able to re-attach it, unless you go the fibreglass route and add new plates as you are doing it
Joe
Old 07-10-2020, 08:42 AM   #7
Different makes have different methods of joining the belly band. I donít know how Ventura does it, but it doesnít appear to work like Casita and Scamp, with turned out lips and fiberglassed on the inside.
It might be like a Trillium... or not.
We need a Ventura owner, or some close-up photos and a good description of how itís joined, including whatís on the inside.
With the heavy leaking youíre describing, Iím going to predict fiberglass work will be required.
'76 Trillium Belly Band Leak Fix georgewa Modifications, Alterations and Updates 6 04-12-2014 09:29 AM
Butyl tape - putty tape? Janb313 Problem Solving | Owners Helping Owners 10 03-23-2013 10:21 PM
Trillium Fix Update - Belly Band Caulk Ruth C. Problem Solving | Owners Helping Owners 1 06-16-2011 10:37 AM
Compact juniors: tape: vertical belly band Kent I Problem Solving | Owners Helping Owners 12 11-25-2008 01:05 AM
Butyl tape vs. butyl caulk- newbie looking for input Jason, M Problem Solving | Owners Helping Owners 9 08-11-2008 02:57 PM
