Hi:
Help...
I own a 2003
Bigfoot 21ft RB travel trailer. This floor plan came with a cabinet just inside the entrance on the left. The PO removed the small door above and mounted a TV monitor which I have since removed. If someone in the “Bigfoot”family has this cabinet with the door, I would appreciate the measurements so that I can have one made. Also the laminate on the cabinet frame was damaged when the PO mounted the TV. Looks like a “wood grain” contact paper. So, if anyone has come across this issue please share what you have done or can suggest a repair shop.
Thank you
