Can't find furnace - Fiberglass RV
Old 05-23-2017, 05:23 AM   #1
Devin's Avatar
Trailer: Collins fifth wheel
Arkansas
Can't find furnace
Hey there. I bought a 1993 Collins 30 foot fifth wheel and I can't find the furnace. I got the gas flowing and the stove lights but not sure how I light my water heater or my heater in general. Don't have a manual and I've looked all over for the furnace. Thanks
Devin is offline   Reply With Quote
Old 05-23-2017, 05:31 AM   #2
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
You might have to light the water heater from outside. But I wouldn't be surprised if there is a switch or switches inside, and the heater probably lights when you push the thermostat lever to on.
Old 05-23-2017, 05:33 AM   #3
Devin's Avatar
Arkansas
Hey thank you! I also saw that it could be the pigtails on my auto switch regulator. Something about the pressure not being correct so it won't flow through the pigtails. Does this sound familiar?
Old 05-23-2017, 05:36 AM   #4
CPW
CPW's Avatar
I've heard of it happening but if you can light the stove it's probably not a problem.
Old 05-23-2017, 05:38 AM   #5
Devin's Avatar
Arkansas
So is there not a pilot to light?
Old 05-23-2017, 05:41 AM   #6
mszabo's Avatar
Trailer: U-Haul VT16
Hello Devin, weclome to the fiberglass rv site. You may not find alot of help here, because very few on use have stick built trailers. Even fewer 5th wheels.
You may find your furnace next to the water heater. Look on the outside of trailer for the exhaust. Photos I've seen show an access cover there.
Good luck!
Old 05-23-2017, 05:42 AM   #7
Devin's Avatar
Arkansas
Thank you
Old 05-23-2017, 06:03 AM   #8
mszabo's Avatar
Devin, make sure you have water in your water heater before lighting.
You will damged it if there is no water in it.
Your furnace is most likely all electronic.
Slow down and take a breath. Located your appliances and right down the model numbers.
Google owners manuals for those models and learn how they operate first.
You dont want to damage any items because you wont like the cost to replace them.
Old 05-23-2017, 06:06 AM   #9
Devin's Avatar
Arkansas
OK I'll slow down. LOL. I understand. Yes there was a light switch for the water heater but a warning that said do not turn on until you fill up the water heater. I appreciate your help. I read something about the pigtails on the regulator. If the pressure is not correct it won't flow all the way through the trailer. The guy that said that said that his stove did work but it wasn't going all the way through to the furnace. Do you think maybe I need to change my regulator and pigtails?
Old 05-23-2017, 06:28 AM   #10
CPW
CPW's Avatar
I would start with the pigtails first. $12-$15 each. The regulator is probably close to $60. But fill the water heater by connecting a hose and then opening the hot water on the faucet. When it stops "spitting," the water heater will be full. Then turn it on. If you are near the water heater and listen, you will hear it the burner. It could also be a 2-way heater that will run on 120 vac also.
Old 05-23-2017, 06:31 AM   #11
Devin's Avatar
Arkansas
Old 05-23-2017, 06:37 AM   #12
CPW
CPW's Avatar
Decent price, Devin. But before going for it, try to light the water heater and furnace first. No sense spending money unnecessarily.
Old 05-23-2017, 06:38 AM   #13
Devin's Avatar
Arkansas
Old 05-23-2017, 06:48 AM   #14
mszabo's Avatar
Your regulator is fine. You most likely have air the gas lines. Your stove is the easiest to light. Since you open the valve lets the air out of line and lights.
The air get compressed going to the other appliances. Sometimes you have to blead it off.
I still think you will be best off too identify what you have first, learn how it operates.
Im sure you'll find everthing is ok and its operator error.
It's all a learning curve.
Old 05-23-2017, 06:52 AM   #15
Devin's Avatar
Arkansas
I don't even know how to go about locating the furnace itself. If it's electric than there would be no pilot, correct? So I should bleed the gas lined by turning the stove on?
Old 05-23-2017, 07:17 AM   #16
Devin's Avatar
Arkansas
So this is my Hydro flame furnace. I think. How would I light this thing?
Old 05-23-2017, 07:29 AM   #17
CPW
CPW's Avatar
So this is my Hydro flame furnace. I think. How would I light this thing?Attachment 106405
Most RV furnaces do not need to be lit. They are started by a 12v ignition system when you push the thermostat up to the desired temperature. If there is air in the line it will eventually clear. If it doesn't start, it could be caused by a bad thermostat, a bad sail switch, a door or insect clogged burner, etc.
Old 05-23-2017, 08:09 AM   #18
Troubleshoot Hydro flame furnace
Old 05-23-2017, 10:05 AM   #19
I did not know there was a trailer named after me! What is a "Collins"?
Old 05-23-2017, 11:14 AM   #20
CPW
CPW's Avatar
Are you sure you weren't named after the trailer?
furnace
Why can't I find past discussions on Awnings? Mike Montville Forum Admin, News & Announcements 2 03-13-2008 10:29 PM
I can't find the VIN mwinslow Problem Solving | Owners Helping Owners 4 04-26-2007 02:40 PM
I can't find this bulb MyronL Problem Solving | Owners Helping Owners 6 11-17-2005 01:15 PM
HELP I can't find new mouding Legacy Posts Problem Solving | Owners Helping Owners 4 07-23-2003 06:12 PM
Why can't I find past discussions on Awnings? Mike Montville General Chat 0 01-01-1970 12:00 AM
