Casita emergency exit window inoperable - Page 2 - Fiberglass RV
Old 07-31-2024, 04:48 AM   #21
Meira's Avatar
Trailer: 2002 Casita 16 SD (as of 7/20/24)
NY
I ended up doing the same -- slowly nudging it open . . . ok, I may have jammed a flathead in some spots to check the resistance . . . and it came loose just fine. I said 'yay' and closed it again before mosquitoes got in.
Thanks for the little bit of encouragement I needed
Originally Posted by David NY View Post
I was too and slowly kept nudging it open. The frame flexed a bit then it popped open on the hinges.
I think it’s wise to have someone on the outside keeping a little pressure on it so you don’t pop it out to hard. I took a chance and got lucky. Good luck.
2002 Casita Spirit Deluxe 16’, new to me: July 2024
Towing with a 2015 Honda Pilot
Meira is offline   Reply With Quote
casita
Emergency exit window in Casita FD Igeowa Problem Solving | Owners Helping Owners 0 07-08-2020 11:37 PM
Swapping emergency exit window BatDude Problem Solving | Owners Helping Owners 6 06-27-2019 02:46 PM
EggCamper EXIT window seal leak photodusty Problem Solving | Owners Helping Owners 2 08-29-2018 05:35 AM
Low Cost Exit window ventilation without the back stabber tractors1 Problem Solving | Owners Helping Owners 1 08-27-2018 11:17 PM
Problems with latch on Casita exit window Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 11-27-2002 11:29 AM
