Casita rebuild door, window and walls - Fiberglass RV
Old 04-17-2024, 08:46 AM   #1
Illinois
Hi all. I am rehabbing a 96 Casita Spirit. The door needs to be replaced, but I am having a hard time finding one because it is the curved model. Any suggestions on where to look?
The back window is also cracked and broken. Again it is curved, which seems to make it harder to find one to replace it. Any suggestions?
Previous owners had also taken the carpet off and replaced it with cork. That obviously didn’t work well and had become moldy. I have removed that and cleaned things up but am trying to decide what to put on the walls. I have found a marine grade half inch pad with vinyl lining that is typically used for upholstery. Do you think this would work? I am not opposed to the carpet but can’t find it with the pad like Casita uses. I also thought the vinyl would be easier to clean, especially because I have dogs.
Thank you in advance! I really appreciate all of the suggestions!
Cyndee is offline   Reply With Quote
Old 04-30-2024, 08:48 PM   #2
Mitten Mitsie's Avatar
Trailer: Trail Mite
What did you end up doing for the window? I'm replacing a similar one. Did you use Lexan or Plexiglas?
Mitten Mitsie is offline   Reply With Quote
Old 05-01-2024, 01:15 PM   #3
Illinois
So I’m still working on it, but I am using plexiglass. I went to Lowe’s and they cut it to the sizes that I needed, but they only do straight cuts. So I am going to use a Dremel to make the curved corners. One of the plexiglasses (Tufak I think it was called) is made it be stronger and shatter proof, so I am using that. I am trying to find the seal that then goes between the frame and the window to help hold it in place. I am now working with Pelland Industries to try to figure out the right seal. Someone on one of the facebook groups suggested them as the place to go for that. It’s a lot more steps than I expected and is taking longer than I thought it would but I’m hoping these solutions work.
Old 05-01-2024, 08:06 PM   #4
Trailer: Trail Mite
After watching a bunch of you tube videos I've found that the seal is called a rubber locking gasket. Some videos show a one piece locking gasket, some show a two piece where you buy the rubber locking key separately (that's also a rubber strip, even though it says key. You'll need a special tool for installation. I am pretty sure both seals work and is just a preference. I plan to use the same one that is on my camper, I hope. I'll find out tomorrow when I remove it.) These gaskets are categorized as Window Mount Gaskets. I found a few at Steele Rubber ( https://www.steelerubber.com/camper-rv/window-mount-gasket ). I hope this gives you some help. Thank you for your response.
casita
Vintage Scamp Door Window Rebuild K Ann Care and Feeding of Molded Fiberglass Trailers 5 05-12-2024 04:29 PM
Vintage Casita window replacement / rebuild questions saucesquatch Problem Solving | Owners Helping Owners 15 12-20-2023 10:55 AM
Success with Int paint walls,countertops,Cabinets, Carpet for floors. Walls, too? Gigi Problem Solving | Owners Helping Owners 2 08-31-2012 11:13 AM
Casita carpet....... Walls and Ceiling Robin G Problem Solving | Owners Helping Owners 52 06-18-2008 05:12 PM
Casita carpet....... Walls and Ceiling Robin G Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
