Caution trailer brakes - Fiberglass RV
Old 02-27-2021, 04:09 PM   #1
It was 40 degrees out today so I decided to pull the wheels off the passenger side of my trailer so I could take them in for tire replacement
When I got the wheels removed (Dual axle) , I notice 2 blue wires hanging in mid air by one wheel . The brake connections had broken at the crimp sleeves
Not a difficult fix but if I had not pulled the wheels I may never have found the problem
I will now add checking the brake wiring to my Spring / Fall maintenance schedule
Old 02-27-2021, 04:44 PM   #2
Here in Virginia we must have a safety inspection each year if the trailer has brakes. They check lights, brakes and emergency disconnect switch.
Old 02-27-2021, 04:46 PM   #3
An ease way to do a check is with a compass. You have someone activate the brakes and you place a compass near the hub and if the electro magnets are energized, the compass needle will move.
Old 02-27-2021, 05:23 PM   #4
Trailer: 28' Bigfoot Silver Cloud
Woodstock, IL
Glad you found the faulty brakes before the first trip!
Old 02-27-2021, 05:57 PM   #5
Thank You — We have our first trip planned for May 2021 but it is contingent on us getting our Covid vaccination shots - So far it doesn’t look promising
We were #300 on the list in late January and as of last Friday we had moved up the list to # 270
All we can do is wait and hope
Old 02-27-2021, 06:58 PM   #6
One thing I like about the P3 is the current readout on the dash. If you are used to the brake setup you will immediately know it a brake is not making connection.
redbarron55 is online now   Reply With Quote
Old 02-27-2021, 09:21 PM   #7
Its even better than that.. you don't even need to go to the display of current (or voltage) because the P3 (and maybe P2 also?) will show an error condition in the situation with the broken wire that the OP described.
Old 02-27-2021, 10:12 PM   #8
Raspy's Avatar
Trailer: Black Series HQ19
Smith Valley, Nevada
Gordon,
Will that show if one out of four is disconnected? Or is it more an indicator that the plug is not connected?
Darwin,
How does the inspector know all four brakes are working? I like the compass idea. That is beautifully simple.
Old 02-28-2021, 07:44 AM   #9
Raz
Raz's Avatar
Vermont
The P2 Prodigy controllers pulse the line. If you sit in the trailer quietly you can hear it. I believe they look for a current draw. Since the controller can be used for multiple axles, they all would need to be open to get the n.c. reading. Unlike the P3, a numerical reading is voltage.
But, if you know the magnet current, by placing an ammeter between the 12 volt pin and the brake line pin on the 7 pin socket, you can determine if all your magnets are connected. For example, my single axle brake magnets draw a nominal 2.5 A. each. Ideally I should read 5.0 A. Typically, I get a little less depending on the trailer battery charge and how long I leave the magnets connected. Since Dexter doesn't specify what voltage was used, I assume any reading above 4.25 A., things are good. Of course the condition of the magnets requires inspection. A good argument for periodic servicing.
Old 02-28-2021, 10:03 AM   #10
Raspy's Avatar
Raz, It seems all, or many modern trucks, with built in brake controllers use the same strategy to prove the trailer brakes are connected. A pulsed voltage is sent down the line about once per second looking for a complete circuit instead of an open circuit. This caused me some trouble on the Black Series trailer because it flashed the tail lights. It looked sort of like the flashers were on, all the time. I tried a couple of ways to make it stop, and finally re-wired the brake circuit from the tongue back and snipped off the factory wiring back near the axles.
It seems the brake test pulses were feeding back through the breakaway battery, through diodes connecting it to the lighting circuit, and firing the LED tail lights. I removed the breakaway battery, its charger and the interconnecting diodes, to simplify the system. Now the breakaway system is powered by the house batteries, which are always connected to the tow when the trailer is connected to the tow.
Old 02-28-2021, 10:13 AM   #11
Once you have basically measured your at rest brake current you can compare each time you hook up and for that matter when you are stopped.
It will let you know if the brakes are not connected, which has warned me several times when corrosion has interrupted the connection in my LED adapter cable.
Old 02-28-2021, 10:14 AM   #12
AC0GV's Avatar
Wisconsin
Testing brake wiring
Measuring current will let you know if the wiring is good. Connect the amp meter from the 12-volt pin to the brake pin and you should measure the full current of the brakes.
Mine is a single axle and the 10-amp max meter works for me. If you have a tandem axle you will need a bigger meter.
AC0GV is online now   Reply With Quote
Old 02-28-2021, 11:31 AM   #13
Trailer: Trail Cruiser
Good to know and easy to do.
Mike_L is online now   Reply With Quote
Old 02-28-2021, 11:32 AM   #14
Originally Posted by Raspy View Post
Gordon,
Thats a good question and I am not sure enough to say.
However as others have pointed out, the P3 does have screens to display voltage or current (amps). So if you check the readings when stopped, and later at stop you check again and the current is 3/4 of the original value or less, then that would be a good clue that at least one brakes were not connected.
Old 02-28-2021, 11:56 AM   #15
Gordon,
Darwin,
Test it at each hub.
Old 02-28-2021, 12:02 PM   #16
Me, I use the gravel test.
B 4 Going on a trip I go forward and lock the camper brakes and and the wheels will dig into the gravel. Once on pavement, I burn off the winter rust to insure I have good brakes.
Old 02-28-2021, 12:59 PM   #17
Been there Darwin, done that LOL
Old 02-28-2021, 01:09 PM   #18
Raspy's Avatar
I do the same thing, every time we leave.
Old 02-28-2021, 01:50 PM   #19
Raz
Raz's Avatar
Vermont
When measuring the current, I suggest metal strips inserted into the socket. This will avoid pitting damage to the socket conductors. I've used old double sided pc board or folded strips of roofing tin.
Old 02-28-2021, 02:07 PM   #20
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
I like the compass idea, or use your new clamp on AC/DC ammeter. You can't take your money with you, and your heirs would love to have one!
https://www.amazon.com/Fluke-Clamp-M...s%2C185&sr=8-5
brakes
Scam? Proceed with caution... Frankly I wouldn't touch this with a 10 ft pole! Robin G Referrals: Molded Fiberglass Trailers 6 08-24-2010 09:39 PM
Caution - Shady underworld Boler flippers at play Darren C General Chat 47 07-09-2007 08:06 AM
CAUTION - New Virus Bigfoot Mike Jokes, Stories & Tall Tales 11 01-10-2007 07:32 AM
Caution - Shady underworld Boler flippers at play Classified Archives 0 01-01-1970 12:00 AM
