Hello there:
New owner of a 2014
Lil Snoozy that I am working on, and have never saw a fuse? switch? panel like this before. What are the little "squeezable" bulbs for on the bottom of the panel? Where are the circuit breakers and how do you re-set them? Took off a wiring panel cover and saw some breaker-like square boxes, labeled with max amps, lying under a bunch of wiring, but they don't appear to have a re-set switch? Do these circuit breakers re-set by themselves when fault is cleared? Do I need to disconnect and remove bunches of wires to get at the circuit breaker re-set?
Thanks in advance......
