City Water - Fiberglass RV
Old 05-09-2018, 05:26 PM   #1
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
City Water
OK.
I have a 2002 Casita FD. Last month I took it to a campground on the GA coast. Hooked up the city water. Everything seemed fine. After a while we noticed that water was coming out of the overflow on the freshwater tank. The tank had been empty. Thus, water was going THROUGH the system and into the freshwater tank.
There were no leaks under the trailer, nor inside the trailer. It was just that the city water hookup was backfilling the freshwater tank!
The pump seemed to be working okay, but isn't it the pump that should stop something like that from happening? The city water hookup worked normally on the trip before that one. We've made no improvements or alterations to the Casita between the two trips.
Any ideas? Is it the pump?
BOBSMITH is offline   Reply With Quote
Old 05-09-2018, 06:54 PM   #2
garyjona's Avatar
Name: Gary & Jona
Trailer: 2015 Oliver Legacy Elite II
Hello I am going to take a shot at this one and say your Water Pump check valve is leaking and allowing water to flow back into your fresh water holding tank. Trace your pipe and I would guess it is the only way possible. Good luck, Thanks Gary
Gary & Jona WPB Florida[/B]
garyjona is offline   Reply With Quote
Old 05-09-2018, 08:57 PM   #3
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
I had that same problem once. I assume that some debris got into the pump from the fresh water tank, past the screen that is between the tank and the pump. The fresh water tank filling system allows all kinds of stuff to fall in, after all. Whatever caused it must have moved on with the water flow. It has not happened again.
Old 05-09-2018, 09:10 PM   #4
BC
So much easier just to fill the tank and use the pump. When the water tank is empty, the holding tank is full so we fill the water and then empty the holding tank.
Any number of horror stories about city water drowning the inside of rv's.
We're lost but we're making good time.
Eggcentric is offline   Reply With Quote
Old 05-09-2018, 10:39 PM   #5
Bob do you use a pressure reducer on the inlet ?
city water fills fresh water tank drmarylynn Plumbing | Systems and Fixtures 10 05-23-2017 08:35 AM
Belly bands and city water and the water drain plugs Cheyanna83 Problem Solving | Owners Helping Owners 0 05-25-2015 07:24 PM
Setting Up city Water Bonnie Problem Solving | Owners Helping Owners 4 11-14-2007 03:45 AM
How to replace city water entry Mo22 Problem Solving | Owners Helping Owners 8 04-21-2007 04:20 PM
