09-23-2007, 05:11 PM
Trailer: 94 Scamp 13 ft
Does anyone know if there is an electric coffee maker with a metal beaker????
Gerry the canoebuilder
Gerry- I don't kow about a metal beaker, but black and decker makes a 1 cup coffee maker that makes coffee directly into the mug. See this link: http://www.blackanddeckerappliances.com/product-54.html
Sheryl
09-23-2007, 05:17 PM
I bought one similar to this at Wal-Mart for <$50
Mr. Coffee Black 8 cup programmable stainless steel thermal carafe
If you tried Google and couldn't find anything, it's because the "holder" is called a Carafe... not a Beaker. (Unless your coffee tastes like a chemistry experiment )
09-24-2007, 01:19 AM
We have that coffee maker -- it's great! The machine heats up the water and drips it into an almost unbreakable stainless steel dewar flask (thermos) that keeps the coffee hot for a couple hours. If you're off-grid you can heat the water on your bunsen burner (stove top) and do a hot water extraction to pull the essential oils and compounds out of the ground raw materials (brew coffee), and it tastes great!
Long live
--Peter
09-24-2007, 10:40 AM
Trailer: 1987 13 ft Casita
Better living through chemistry...
Puala
09-24-2007, 11:19 AM
Long live
Attachment 10213
--Peter
How do you use the water heated on the stove in the coffee maker? In any coffee maker I've had that would have been a forbidden process.
Bobbie
09-24-2007, 04:34 PM
Trailer: 1999 Scamp 16 ft ('The Pod')
Bobbie
You can use the carafe with a cone filter and pour boiling water through it. Bypasses the coffee machine but utilizes the carafe to keep the coffee hot.
How did we go from cargo nets to coffee pots?
Vivian
09-24-2007, 06:57 PM
Vivian
Blame Gerry, he put the question in the middle of his posting and I answered it.
BUT, I have the POWER to split it from the original topic
09-24-2007, 11:50 PM
It's one of the reasons I like this coffee maker. Many coffee makers one door you open for pouring cold water into the reservoir and a separate door that swings the filter compartment out so you can change the filter. With this coffee maker there's just one door that swings up and out of the way, with an unintended benefit being that, when you are off-grid, you can boil water on your stove and slowly pour hot water into the filter basket from the kettle instead of having the coffee maker heat the water for you.
It does mean you have to be patient: pre-measure the water you're boiling into a kettle, boil the water, then pour the hot water just a little bit at a time into the filter basket so you don't overflow the basket, but this hasn't been a problem. I seem to very patient when morning coffee is concerned.
--Peter
09-24-2007, 11:51 PM
Freud had it wrong. It's all about coffee.
09-25-2007, 01:00 AM
Trailer: 1974 Ventura
Personally I have been shopping around for a French Press Coffee carafe thingy. Just boil the water, add to the glass beaker with coffee already added and push down on the plunger.
09-25-2007, 07:10 AM
Trailer: Scamp 13 ft
We switched recently to using an "old school" aluminum Italian espresso maker for our main camping coffeemaker. It is seriously great. You fill the bottom chamber with water, and heat from any source forces steam through the ground coffee up into the top chamber. If you use a lot of coffee you get espresso, a little bit of coffee gives you a nice smooth cup of good strong brew.
It works equally well over the Scamp's stove, our Coleman camp stove, an electric burner, or a campfire. It's basically indestructible. It's tiny and lightweight, another FGRV plus. The predictability factor is great; you can be pretty certain you'll get a decent cup of coffee, which is more than can be said for the various coffee makers we've purchased over the years. It likes a fairly fine grind, so we just grind up a bunch of beans and store them in a plastic container before we head out. (Gotta get a hand powered grinder one of these days!)
[ATTACH][/ATTACH]
(remember that the cup sizes are little espresso cups...)
09-25-2007, 07:16 AM
I just read an interesting article in Chemical and Engineering News on coffee flavor and aroma. (Unfortunately I can't link to it as it is now available only to subscribers.) Anyway, one thing that researchers have concluded is that the coffee flavor and especially aroma degrades within a few hours of brewing, and as it sits, bitterness also increases. They didn't specifically address sitting in a carafe as opposed to sitting on a hot plate, though, and I wonder if that is as bad for the taste. I have been making a pot and then reheating it for each cup, but after reading this article I may start making each cup fresh.
Bobbie
09-25-2007, 08:59 AM
In my coffee investigation I've gone a number of ways and eventually returned to the percolator.
I had a Mr. Coffee drip machine but had to carry a percolator for rustic camping. Two pieces of equipment.
Tried the coffee press but it was too messy and used too much water for clean up. My grey water capacity is too low to waste it on cleaning the press' filter. I was heating the water to pour into the press in a percolator without the basket in it anyhow.
The Coleman stove top unit is attractive but too much of a space hog for my tastes.
In the end I bought a nice stainless percolator at the local REI (though a Cabelas unit would do the job as well), plus some of those paper filters made for percolators. Keeps the grounds in a toss-able package, keeps the second cup warm and it satisfies my sense of the camping experience.
I think the "cowboys" toss egg shells into the grounds or something but there's a limit... even for me.
Without adult supervision...
Also,
09-25-2007, 10:10 AM
I just read an interesting article in Chemical and Engineering News on coffee flavor and aroma. (Unfortunately I can't link to it as it is now available only to subscribers.) Anyway, one thing that researchers have concluded is that the coffee flavor and especially aroma degrades within a few hours of brewing, and as it sits, bitterness also increases. ...
Bobbie
I had a brief stint at Starbucks. The difference in a straight shot of espresso in less than a minute is amazing. So if you have a quick method of creating two shots in a row (with about 30 seconds between), taste the difference. Maybe your local Starbucks will indulge you with that experiment. It's required learning when working there. The key with the drinks is to get the espresso in it's steamed milk quickly then it stabilizes (to a degree).
I refuse to reheat coffee. Plus I'm getting to the point of thinking about ditching the almighty microwave. It mixes up the particles too much. I've read things...
Paula
09-25-2007, 05:04 PM
There's a thread in General Chat about coffeemakers. Bialetti, maker of stovetop espresso pots, has come out with the Mukka, a stovetop cappuchino maker where you just put in the water, coffee and milk in separate parts, put it on the LP range and stand back while it produces the finished product! Not inexpensive at $90, however.
For French Presses, I have one of these, Big Sky Bistro Press. Insulated cup to keep the drink warm outside at the picnic table, plus it's good for hot or cold stuf besides coffee.
09-25-2007, 09:44 PM
Plus I'm getting to the point of thinking about ditching the almighty microwave. [b]It mixes up the particles too much. I've read things...
Paula
I think you're confusing it with the transporter.
Beam me up, Scotty...
09-26-2007, 12:31 PM
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
09-26-2007, 12:44 PM
Speaking to the aroma of the coffee only, it doesn't matter WHAT you do with it. Within minutes of being brewed the molecules responsible for the odor start to change and the aroma decreases. Hot, cold, canned, makes no difference.
Bitterness primarily develops during roasting. The compounds contributing to bitterness are primarily lactones and phenylindanes. The longer you keep brewed coffee hot, the more the acidit increases, because the lactones turn into free acids. This influences the perceived bitterness.
(Chemist, not Chemical Engineer, but the article is from Chemical & Engineering News.
Bobbie
09-26-2007, 03:40 PM
The reason I don't like microwaved coffee is that it tastes too radary.
09-26-2007, 04:08 PM
Trailer: Beachcomber
yupper's got me one of these coffee brewer's....from doughnut's to sittin in the trailer to coffee....
good topics for this cool fall day.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
How do you make Coffee?
bill&sandra |
Camp Cooking, Food & Recipes |
303 |
06-13-2012 12:13 AM |
World's Best Cup Of Coffee
Al POGUE |
0 |
09-26-2007 09:00 AM |
12V Coffee Pots
Legacy Posts |
17 |
06-15-2003 08:33 PM |
