Hi All,
I have a 1990
Scamp 16 with the original converter and would like to upgrade it to something more modern. I've been scouring related posts which have been helpful. I am not an electrician by any means and need all the help I can get.
While browsing through various posts there was a lot of discussion around grounding the converter to the trailer frame. After reading I came away with the understanding that I should not ground the new converter to the frame. My original converter was not wired to the frame either. Unless a previous owner changed something but I doubt it.
The various posts on grounding seemed to indicate that the only ground is the green wire from the shore power. I guess I'm still confused if there is supposed to be a actual wire grounding the shore power to the frame somewhere? I don't see one on my trailer. I did the power cord conversion a few years ago and replaced with the external twist lock. I'm just wondering if I screwed something up when I changed that. I don't recall seeing any wires running to the frame and I can't imagine I would have removed it but you never know.
As far as installing the new converter I am not planning on grounding it to the frame. Did I misinterpret what I read or is that correct?
I have not ordered anything yet and am just trying to make sure I understand how exactly to wire the new converter and fuse box before I purchase something I can't install.
Generally my understanding is that I connect the positive (black wire) from the
battery to the fuse block and the new converter. I connect the negative (white wire) from the
battery to the ground bus terminal on the fuse block. I also connect the negative from the converter to the ground bus terminal. From there connect the various appliances (water pump and heater) to the fuse block. Am I missing anything there?
Any help would be appreciated.
Thanks
Kelly
