cracked dometic shelf - Fiberglass RV
Old 06-06-2020, 04:23 PM   #1
Hi all,
Any suggestions on a good glue to use when repairing a cracked Dometic fridge door shelf?
Thanks in advance!
biker is offline   Reply With Quote
Old 06-06-2020, 08:40 PM   #2
Trailer: 2013Escape 21
Iowa
I like JB Weld products. I’m not sure which one because they have a complete line of epoxy products. I assume your shelf is plastic.
Iowa Dave
Iowa Dave is online now   Reply With Quote
Old 06-06-2020, 10:16 PM   #3
I used a two part epoxy to fix my shelf, but it is reinforced with aluminum. Been fixed for years now.
Old 06-07-2020, 05:46 AM   #4
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I, too, like Glenn used clear two part epoxy to repair a crack in a Dometic shelf. It was one of the horizontal slide in shelves, and the crack was in the middle up front, presumably from items bouncing up and down while traveling. Since it could be removed, I placed the shelf upside down and found a dowel that perfectly fit in the channel where the crack had occurred and cut it to the proper length. Next I mixed and put a layer of epoxy in the circular groove and put the dowel in place. The next day after it hardened I mixed a large amount of epoxy and put it on top of the dowel, enough to bring it up to the edges of the groove. The result was that the somewhat flimsy plastic shelf can no longer flex as the weakest side is now reinforced; the other three sides are supported by extensions on the internal refrigerator surfaces. The epoxy has held up through heat when the refrigerator is turned off and through cold when the refrigerator is in use. In reality, we shouldn’t have to make this type of repair. Dometic (and other manufacturers) should provide more durable products.
Old 06-07-2020, 11:25 AM   #5
Trailer: Outback trillium trailer
fridge shelf
Hello biker do you have the Dometic RM of the fridge, you could get a used on thats not compromised for probably the same cost of the epoxy, we have well over 200 used fridges here
Joe at Outback is offline   Reply With Quote
Old 06-07-2020, 12:42 PM   #6
CPW
CPW's Avatar
Well, that would be quite a bargain given that epoxy might cost $5.99 and the shipping cost alone of a used part from Alberta to Texas would be how much? However, I would agree that a non-compromised part would likely be the better solution.
1978 vintage RM211 dometic shelf retainers Russ Problem Solving | Owners Helping Owners 3 11-27-2015 10:59 AM
Dometic door shelf bracket Scouter Dave Problem Solving | Owners Helping Owners 5 05-14-2012 05:35 AM
Trillium: Cracked Battery Shelf Raz Problem Solving | Owners Helping Owners 21 04-20-2012 04:29 PM
Cracked Window Gerry Problem Solving | Owners Helping Owners 10 11-06-2006 06:50 AM
» Trailer Showcase
Baguette
Ryaine
Casita
Ed F
