Creaky Fiamma awning - lubrication? - Fiberglass RV
Old 03-29-2017, 11:42 AM   #1
DougOlson's Avatar
Trailer: Escape
The Fiamma awning on my 2015 Scamp 16 is rather creaky and sounds to me like it could use some lubrication. It's been through some rain in travels the last two years. I did not find any info on lubrication maintenance in the manual. Any advice before I start squirting some kind of lubricant on all the moving parts? Thx
DougOlson is offline   Reply With Quote
Old 03-30-2017, 09:17 AM   #2
That's a good question. We just bought a Parkliner (in Oct '16) with a Fiamma 45 crank out awning, I went to the Fiamma website and pulled up the instructions.
After wading through five langages ... I found no mention of lubrication.
If the joints and pivot points are plastic on metal, It might be best to avoid and lubricants. They can just collect dust. Dirt and oil makes a grinding compound that can make things wear faster. Perhaps a good cleaning with clear water and an dry with an air gun to dislodge any dirt...?
Old 03-30-2017, 10:58 AM   #3
Trailer: 2016 13Ft Scamp
Q - What maintenance should I perform on my awning?
A - We recommend lubricating the spring loaded lateral arms at the elbows and at both ends every six months with a spray lubricant. Use silicone or a similar product to keep the awning running smooth and free. Also, we recommend lubricating the swivel joints at the top of the legs.
Fiamma Inc. - Service
EugeneFlorida is offline   Reply With Quote
Old 03-30-2017, 11:30 AM   #4
DougOlson's Avatar
Trailer: Escape
Thanks for posting the answer here. I eventually found that Q&A with some Google searching. You should consider adding that to the Fiamma owners manual.
Old 03-30-2017, 02:11 PM   #5
Tri-Flow lubricant is a spray lube made with PTFE (teflon).
It works great on all sorts of materials like plastic on metal hinges etc.
It is better than silicone spray which would likely do well on your awning frame.
It also comes in a squeeze bottle.
Old 03-30-2017, 02:47 PM   #6
I stand corrected, thanks. And thanks for the tip, Floyd.
awning
Adjust an A&E or Fiamma Crank Awning Donna D. Problem Solving | Owners Helping Owners 0 03-21-2011 07:57 PM
Fiamma Awning! BOBSMITH General Chat 27 07-02-2009 04:34 PM
Removed Fiamma Awning BOBSMITH Care and Feeding of Molded Fiberglass Trailers 6 06-09-2009 07:31 AM
Bearing Lubrication Donald Stahl General Chat 1 08-10-2007 02:16 PM
