I am rewiring my DC fuse panel & need help
There is a 40a main fuse that went to a removed converter -- Can I wire this as power in from a positive bus bar off a 2
battery bank?
The negative either goes to a fuse 30a that is labeled as negative ? Or to an existing negative fuse panel bus bar ? Which one?
If the bus bar, where would I likely wire this remaining fuse (30a) that's labeled as negative?
The dc fuse panel door shows a negative white to the
battery but I don't believe this is existing.
Help would he greatly appreciated, even just opinions, cheers
