Hi everyone
I'm in the process of renovating a
Cadet as you call them or N126 as known in Poland.
I have an original window that at first I thought I need to replace. Its double glazed or laminated. The flat piece unfortunately has a bad crack and I see it has started to separate in several areas. The front moulded part is fine.
What I am thinking is that IF I could continue the delamination somehow and completely separate the two pieces I could cut and replace the cracked part. Just flat perspex. Buy the special liquid and join again.
Has anyone tried this? Could perhaps suggest a course of action. Basically I have little to lose. If I screw up I buy a new window which I would have to anyway.
Cheers for any ideas.
