Digital thermostat for older Bigfoot - Fiberglass RV
Old 03-11-2021, 02:19 PM   #1
Trailer: Bigfoot 17G
Can anyone recommend a digital thermostat that can replace the simple 2-wire OEM thermostat in a 1995 Bigfoot trailer?
bobblangley is offline   Reply With Quote
Old 03-11-2021, 03:47 PM   #2
I replaced my analogue thermostat with this, non programmable. Easy install.
Old 03-11-2021, 04:05 PM   #3
Thanks, Glenn. I can't tell from your photo so could you please tell me the two terminals that your wires are attached to?
I have a Luxpro low voltage thermostat with terminals labeled "G", W1", and "RH".
I am hoping your terminals are "W1" and "RH" and that this thermostat might work.
Old 03-11-2021, 04:35 PM   #4
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
Bob I just bought a new analogue. OEM .
My furnace would not come on, I have to move the temperature lever low to high back and forth several times before I hear the furnace gas solenoid click on and the pilot light come on. I thought a new thermostat would fix that. I go thru the same scenario with the new thermostat.
That is why I didn't buy a digital.
The electric surge coming from the thermostat to the solenoid seems to make the solenoid work. Is my thinking correct ??? I didn't know if a digital would work by just turning it on, temp preset.
I wanted a digital !
Thanks Kenny
Kenny Strong is offline   Reply With Quote
Old 03-11-2021, 04:43 PM   #5
I just took out the OEM thermostat and wired in the Luxpro. Everything seems to work quite well.
Old 03-11-2021, 04:48 PM   #6
The two R terminals have a u-shaped jumper in them. Green wire goes in top one. All I know is it works.
Old 03-11-2021, 04:51 PM   #7
I replaced the analogue one because it made a loud click when it turned on and that would wake me up. Thermostat was right above my head, in bed. Then I'd lay awake waiting for the furnace to cycle through.
Old 03-11-2021, 06:18 PM   #8
I never keep mine on at night; just use a good down sleeping bag. I am pretty sure that the digital thermostat still clicks in pretty much the same way as the analog did.
I also added a Wave 3 heater.
Old 03-11-2021, 06:23 PM   #9
Mine does not. That's the only reason I replaced the analogue.
Old 03-11-2021, 06:29 PM   #10
That's a good thing. There's not much worse than lying in bed waiting for a sound you know is going to happen sooner or later but not knowing just when that will be.
Old 03-14-2021, 03:15 AM   #11
Julie T.'s Avatar
Trailer: Scamp 13 ft
I have a 2005 25RQ and swapped it out for this one.
Honeywell TH1100DV1000 Nonprogrammable Heat Only Thermostat, White https://www.amazon.com/dp/B00H6ARNXO...ing=UTF8&psc=1
Julie T. is offline   Reply With Quote
Old 03-18-2021, 09:01 AM   #12
Trailer: scamp
Indiana
Depending on how you use it, you might want to rethink this one. Honeywell has a feature that if the temp gets below freezing it stops the furnace. The idea is for a house. And if it gets below freezing that probably meant that the plumbing froze, and so you need to not have the furnace come on and thaw out broken pipes. They are trying to require manual intervention to get the furnace on to require a human to be involved and to be around for watching for problems. Maybe a good idea for houses. They should actually list this as a feature. But horrible idea if you winter camp.
computerspook is offline   Reply With Quote
bigfoot
Scamp Replacement a Digital Thermostat sal6342 Modifications, Alterations and Updates 32 06-02-2019 08:00 AM
Anyone using a digital thermostat? David and Nancy Modifications, Alterations and Updates 16 04-17-2016 10:16 AM
Digital thermostat delima Anders Laurits Problem Solving | Owners Helping Owners 0 05-23-2015 12:02 PM
Digital Heater Thermostat? chuyler1 Modifications, Alterations and Updates 17 06-11-2014 07:37 AM
Surburban Propane Digital Thermostat. Oliver P Modifications, Alterations and Updates 16 01-14-2010 01:36 PM
