Do I have a problem with my roof? - Fiberglass RV
Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-08-2021, 11:37 PM   #1
Trailer: Scamp 13 Layout 2
Purchased this 2016 Scamp 13 used two days ago, and I am concerned I may have a problem with my roof. The AC unit appears to be tilted towards the curb side an inch or so. I tried to take a photo of what I am seeing, but it may not show up well. Is this normal? The rest of the trailer is in beautiful condition. I checked the four mounting bolts for the AC and they are all snug and there are zero signs of a leak inside around the fan or air conditioner.
tradcatholic is offline   Reply With Quote
Old 12-08-2021, 11:51 PM   #2
Level the trailer then put a bubble level on the AC. That would be my first test.
CalCop is offline   Reply With Quote
Old 12-08-2021, 11:53 PM   #3
AC0GV's Avatar
Wisconsin
Maybe not
If there are no leaks and no damage it may just be the way it came out of the mold. Mine is a 2017 and has a small sag in the roof. I do support the roof with a pole when on long trips and rough roads. Is the space under the A/C to the roof the same all the way around? I'm not saying our roof pitch is a good thing, but may not hurt anything. Here is a close up of yours.
Old 12-09-2021, 12:12 AM   #4
Great idea on checking around the AC unit for distance. I used a Bosch DLR130 laser distance meter, and put it against the roof on each side of the AC unit. I got between a 1/4" and 1/8" difference between each side. I took three measurements and they all showed between 1/4" and 1/8" difference. I'm thinking maybe it was built that way?
Old 12-10-2021, 08:46 AM   #5
GOB
Trailer: Scamp 19
Ac not level
From your picture it appears that the AC is installed off center of the roof which could lead to it being not level because the roof slopes for drainage. If it doesn't leak I would call it good.
GOB is offline   Reply With Quote
Old 12-10-2021, 08:56 AM   #6
GOB,
You have good eyes! I actually sent the photo to Eveland's, and they responded almost immediately, and asked for me to measure the A/C. Sure enough, it is slightly off-center. I checked and it is centered in the hole that was cut. Scamp said that the hole is likely cut slightly off center, and said that moving it could damage the roof or the AC gasket, and confirmed that being off-center just a bit will not hurt or damage anything, as long as there are no leaks. We got rain last night and everything is bone dry inside and around the AC, so it seems I am all good! After 7 years of owning stickie RVs, I am really looking forward to adventures in my little egg, which I have dubbed "Shrimp Scampi"!
I just noticed the introductions section, so I suppose I should mosey on over there and formally introduce myself!
Old 12-15-2021, 11:36 AM   #7
Before I purchased my Trillium I looked at two trailers with a rooftop AC units. Both appeared to cause the roof to sag, one had a spongy floor underneath it. After replacing the vent in my Trillium i realized there’s not a lot of structural strength in the roof. In general I think after market, roof mounted AC units on fiberglass trailers should be carefully checked out.
Thomas W is offline   Reply With Quote
New 1987 Big Foot owners with sagging roof problem... cjamie02 Hi, I am.... 0 08-23-2016 04:52 PM
Battery problem or system problem? Uplander Problem Solving | Owners Helping Owners 4 06-01-2015 04:39 PM
Trillium Roof Problem Gene B Problem Solving | Owners Helping Owners 1 05-31-2009 08:30 AM
I think I have the DMV/DOL problem figured out! Bobbie Mayer Problem Solving | Owners Helping Owners 11 03-22-2007 05:30 PM
