Does anybody know what the red glue is that scamp uses - Fiberglass RV
Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-02-2021, 07:30 PM   #1
Alaska
I'm peeling back a bunch of the rat fur and insulation for a bunk support replacement project. That red glue is super sticky. What's the equivalent I can use to get it all back in place up against the shell?
pwzummer is offline   Reply With Quote
Old 10-02-2021, 09:16 PM   #2
3M-77 or 90 spray adhesive.
Old 10-03-2021, 01:02 PM   #3
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
Phil
remove the old sticky red contact cement with lacquer thinner rather than spray over it. Old contact cement should be dry to the touch, and it can be sprayed over. New spray should be tacky, to determine if it is ready, you dab a piece of paper against the sprayed surface if it sticks it is not ready.
Kenny Strong is offline   Reply With Quote
Old 10-04-2021, 08:52 AM   #4
I would caution against 3M77. It’s a light duty, craft-grade adhesive for paper and cloth. It’s for indoor use and won’t stand up to high temperatures and moisture. I have read too many accounts of failures when used to attach headliner. Go with 3M90.
Old 10-09-2021, 04:44 PM   #5
Trailer: scamp
Kansas
Red face glue
When I removed the elephant skin and cleaned the surface with Lacquer thinner, I them modified a spray gun and sprayed contact cement on the surface and the back side of the rat fur. It worked real well. Click image for larger version
jars is offline   Reply With Quote
Old 10-09-2021, 08:41 PM   #6
Trailer: Currently waiting
Scamp glue
This is what the Scamp repair shop sent me to fix an issue on my new Scamp.
L Thompson is offline   Reply With Quote
Old 10-09-2021, 09:42 PM   #7
Alaska
Is that an aerosol spray can?
Old 10-09-2021, 10:11 PM   #8
AC0GV's Avatar
Wisconsin
Never heard of it
Looks interesting.
https://helmitin.com/product/helmistik-1685/
Old 10-09-2021, 10:52 PM   #9
Alaska
Looks like it's harder to find than 3m 90 spray. Can't even get that up here in Alaska
Old 10-10-2021, 11:16 AM   #10
Utah
Phil
I bought spray can 18 oz. 3M Headliner Adhesive on Amazon
It states on the can;;; " Exceptional strength bonds heavyweight automotive fabric and foam headliner materials ".
I looked for code number found none.
I had some torn foam resilient foam bedding , worked well. I have used spray contact cement in wood working, 3M is a good product.
Old 10-10-2021, 12:53 PM   #11
Alaska
Originally Posted by Kenny Strong View Post
Phil
I've noticed there's a number of different 3m products that are identified as headliner adhesive. Is the one you use called yellow headliner adhesive? That's the only kind I can find at auto parts stores
Old 10-12-2021, 11:15 AM   #12
Utah
Phil
my thinking. Red color when spraying.
color depth or intensity lets one know how much has been applied to the surface. spraying the inside of our egg shells with a color close to the color of the fiberglass would be hard to tell where you have been
yellow, is used used in industrial mechanical spraying, it is controlled by settings
I never hand sprayed large surfaces with a yellow. I have bought gallons and quarts; all yellow, hand painted or rolled.
I have only seen red contact cement in 5 and 55 gal. drums for work shop spraying
Anybody know the history of the Trillium Jubilee? Booker B. Care and Feeding of Molded Fiberglass Trailers 38 04-23-2021 08:34 AM
Red face Question For Accrete, Thom and Cari's ParkLiner, Anybody bluebird Problem Solving | Owners Helping Owners 0 01-28-2020 11:51 AM
What glue is the best to glue the fabric on the sealing. Falicea Problem Solving | Owners Helping Owners 11 10-31-2017 09:22 PM
Anybody Know About the Little Joe/Ponderosa? george oviatt Care and Feeding of Molded Fiberglass Trailers 8 10-25-2009 06:46 AM
Is This anybody you know? Byron Kinnaman Jokes, Stories & Tall Tales 0 01-25-2008 11:09 AM
