07-16-2021, 02:18 PM
Trailer: Parkliner 2018
Maryland
Dometic 3 way fridge losing cool on propane
Hive mind help? The only 6x I've had my 2018/19 Parkliner (new to me) out the Dometic 3way fridge has worked flawlessly on propane. I've run it on propane because I heard here that it's colder on gas than electric, and indeed I've had ice crystals on liquids I've had at the rear near the metal/aluminum 'flanges'?
I've been out for 6 days and it's been fine, ran it on gas at 2 campgrounds and while towing until yesterday, the last stop. Upon setting up I noticed that during the tow it had gone from 38 to 44 and it kept climbing. It's level, gas is definitely on but not having any effect.
Sun is not hitting the vent (where you take off the 'door' to start/turn on).
The vent to the left of that, about 5" square that also protrudes about 1/2" that says "HOT" is not even warm.
Any clues as to what is happening? I don't think that a short stop at the Kitchen Witch would have had an affect.  Or would it?
Many thanks.
07-16-2021, 02:33 PM
Trailer: 1979 Boler 1700
Two comments:
- As you have probably observed, gas absorption fridges such as the Dometic 3 way fridge require 24 hours or so to cool down to operating temperature after being turned on. At that point, the fridge temperature will fluctuate based on ambient temperature, generally staying 30 to 40 degrees below ambient temperature. Also these fridges require long temperature recovery time after being opened and after additional warm items are added to the fridge.
- The two vents immediately left of the door are the fridge vents. The upper vent should be warm to hot when the fridge is running. The small vent further to the left labelled HOT is the furnace vent.
07-16-2021, 02:54 PM
Maryland
Thanks John. It's been running fine for 6 days. It's only after/during yesterday's tow to a different campground that the issue began. I'm stumped ::sigh:: I think I'll try to switch it over to electric to see what happens. Many thanks.
07-17-2021, 11:23 AM
Trailer: Scamp 19
Fridge on gas
Plenty of gas in tank? Try switching tanks. Regulator could have gone bad.
07-17-2021, 11:51 AM
Maybe the flame blew out while driving.
07-17-2021, 11:56 AM
Trailer: Casita 17 SD
Clean the jet.
I would guess the flame is out, whether blown out or out of gas.
Also, I haven’t noticed a huge difference between gas and AC, especially once the fridge is cool. I always switch to AC if available. Therefore, I don’t know if I could run my fridge for six days off propane alone. That seems like a tall ask.
I’d check the pilot first and then the tank. But I’d certainly check both.
08-27-2021, 12:11 AM
Trailer: 2018 13' Scamp
I will echo others, guessing the propane blew out, mine does every time I try to use it while pulling the trailer. You can tell by looking at where the propane burns, or feeling for heat
08-27-2021, 08:57 AM
Trailer: 2016 Bigfoot 25RQ
Our propane fridge in our 2001 Scamp 16' quite often quit working going down the road. I added a baffle for driving down the road and it never quit working again.
If you're driving down the road your outside vent will never get hot driving down the road, since it's cooled with the 60+mph air. It should get warm when at your campsite though.
Enjoy,
Perry
08-27-2021, 09:44 AM
Enjoy,
Perry
Perry: that sounds like a worthwhile modification, I think the fridge stays colder on propane than it does on DC, would you have a picture Perry?
thanks, Jeff
08-27-2021, 11:18 AM
Name: Borden and Carole
Ours only works proper on 12v while driving. It has the be cold prior to 12v switch to not drain the battery and works well during trip. At sites the 110v and propane seem to cool the same. We use propane for when shore power is not available.
P.S. we did once have to replace the regulator, drain gunk out of the lines to fix propane problems. New regulator volume had to be professionally adjusted after install. Stove, furnace, hot water tank, and fridge did not all work correctly until gas volume adjustment was made at the regulator. Also had the fridge flame setup at this time.
Our postage stamp in heaven.
08-27-2021, 11:37 AM
Trailer: In the market
It sounds like the flame blew out while driving. I have an older trailer and if my propane runs out or if the igniter is unable to light the propane after a few tries the fridge shuts down for safety and a check light comes on beside the on/off switch. Turn the fridge off for a couple of seconds and then back on. If you listen carefully you will probably hear the spark and the burner start.
Nigel
08-27-2021, 07:28 PM
Maryland
Thank you all for your responses. I have answered as follows to new replies. I will post if successful - or not - on my DIY as CasitaMiner and others on this forum have done.
“Plenty of gas in tank? Try switching tanks. Regulator could have gone bad.”
GOB – yes, plenty of gas. Blue flame, chimney hot, hot. Stove works fine on the same tank.++++
“Maybe the flame blew out while driving.”
SLIM, it was lit, the chimney was hot, hot, flame blue.++++
“Clean the jet.”
CASITAMiner, yes that is going to be my next move. I have the manual, read the pertinent part until I’ve got it memorized and watched youtube vids. I think I’m up to the task but at any rate, I have nothing to lose.++++
“I’d check the pilot first and then the tank. But I’d certainly check both.”
Keith2000, flame on, tanks full. As far as running the fridge on propane, last season I ran it 4 weeks, 1 tank and still had gas in the tank. I did my cooking outside on an electric skillet, but fridge on propane the whole time.++++
“I will echo others, guessing the propane blew out, mine does every time I try to use it while pulling the trailer. You can tell by looking at where the propane burns, or feeling for heat”
JEFFMINNESOTA flame was on and blue. It has never blown out while towing and the chimney was hot, hot.++++
“If you're driving down the road your outside vent will never get hot driving down the road, since it's cooled with the 60+mph air. It should get warm when at your campsite though.”
PERRYB67, the chimney was hot upon arriving, remained hot, flame on, while setting up. After an hour it had warmed up some more with flame on and chimney hot. I switched over to AC but it does not cool as cold as when on propane.++++
“Ours only works proper on 12v while driving. It has the be cold prior to 12v switch to not drain the battery and works well during trip. At sites the 110v and propane seem to cool the same. We use propane for when shore power is not available.”
BORDEN, the only time I’ve run it on 12v while driving, my house battery was deader than a doornail. Didn’t damage it according to the folks that charged it, so I will need to check to see if the truck is charging it through the 7pin.++++
“It sounds like the flame blew out while driving. I have an older trailer and if my propane runs out or if the igniter is unable to light the propane after a few tries the fridge shuts down for safety and a check light comes on beside the on/off switch. Turn the fridge off for a couple of seconds and then back on. If you listen carefully you will probably hear the spark and the burner start.”
Nigel
NIGELW, flame on (sounds like the Torch from the Fantastic Four, right)? And chimney hot. Stove works fine on the same tank. I think I’m going to chance cleaning the jet as CasitaMiner has suggested and a few have done which has fixed the fridge on propane problem.++++
