Dometic Cool Cat air conditioners (under the seat) - Fiberglass RV
Old 04-22-2021, 12:06 PM   #1
MJo
MJo's Avatar
Trailer: 2020 Scamp w/2004 Volvo XC-70
Massachusetts
Does anyone have the Dometic “Cool Cat” airconditioner that fits under the seat? I’m considering getting one, it has the ability to cool and also heat, within limits. Around $1,100 w/o installation. I’m on the Cape, going to Major’s RV if I have one installed.
MJo is offline   Reply With Quote
Old 04-22-2021, 12:41 PM   #2
I have one in my Class B van camper. It’s really noisy, vibrates a lot, and expensive. Not worth it IMO. Get a small ceramic cube heater for heat and a window-type unit for air conditioning.
Old 04-22-2021, 12:50 PM   #3
MJo
MJo's Avatar
Massachusetts
Thanks for the reply. I was thinking of going back to Scamp for A/C but then saw this on the Dometic website and a local dealer would install it. Nice to know I don’t want it before I got it. thanks again.
Old 04-22-2021, 03:47 PM   #4
Borden's Avatar
Name: Borden and Carole
Do you know about the portable battery unit thought of it for in the boot.
Our postage stamp in heaven.
Old 04-22-2021, 04:57 PM   #5
If your Scamp is reinforced for it, roof A/C is simplest and gives the best circulation. It's also fairly noisy and transmits vibration through the shell. Price is likely similar to the CoolCat.
Inexpensive alternative is a window A/C, which can be permanently mounted in a cabinet (requires a largish vent cut in the shell and DIY engineering of baffles and condensation drainage) or temporarily through the rear slider (remove for towing, requires a filler plate to cover the gaps).
Note that the CoolCat will also require an exterior vent cut in the shell.
Window Air Conditioners Frederick L. Simson Problem Solving | Owners Helping Owners 5 05-31-2009 11:14 AM
Cooler Air conditioners mcnick Problem Solving | Owners Helping Owners 10 02-11-2009 01:55 PM
Air Conditioners in Bigfoot yvonne Care and Feeding of Molded Fiberglass Trailers 6 06-22-2008 07:22 AM
Portable air conditioners General Chat 0 01-01-1970 12:00 AM
portable air conditioners General Chat 0 01-01-1970 12:00 AM
