Dometic Refrigerator Not Working on 120 VAC - Fiberglass RV
Old 04-24-2025, 09:18 AM   #1
After a few days of bondocking with our 2020 Casita, we plugged into shore power and found our Dometic refrigerator would not change over to AC. Checked all the fuses and breaker on the converter panel, all were good, so we left it on gas until we got home. After several You Tube videos showing rather complicated fixes, I went looking for the 3 fuses mentioned in operating instructions. Took off the vent panel covers for the first time (just turn slotted knobs 90° then pull corners out) and, before I found the fuses, I saw the power plug was partially out of outlet. Pushed plug in and all was well! As Ockham’s (or Occam’s) razor predicts, the simplest solution worked.
Moyza Frank is offline   Reply With Quote
refrigerator
HELP! Dometic refrigerator not working BUT freezer is! Bhamm1 Problem Solving | Owners Helping Owners 11 08-10-2022 09:28 AM
Dometic RM2454 3 way refrigerator 120 does not work RCF13 Electrical | Charging, Systems, Solar and Generators 4 10-13-2020 07:18 AM
12VDC/120 VAC Flat Screen on WOOT.COM - Won't Last Long..... Bob Miller Problem Solving | Owners Helping Owners 0 09-24-2012 08:44 AM
110 VAC re-wire job done Gerry Modifications, Alterations and Updates 0 06-21-2007 03:41 AM
Problems with Refrigerator on 120 volts John Blair Problem Solving | Owners Helping Owners 14 05-07-2007 02:55 PM
