Dometic RM 2201 freezer door... - Fiberglass RV
Old 08-29-2020, 07:38 AM   #1
Hi All,
I'm curious if anyone here would know where I could source a freezer door for my Dometic RM 2201 3 Way fridge? One of the small tangs from the clip arrangement that is part of the "hinge" on this door has broken off. I will be trying to repair it but it is such that I'm not sure the repair will hold. The tangs pinch over a small rod the runs the height of the door. Thanks.
Larry
Larry Engelmann is offline   Reply With Quote
Old 08-29-2020, 02:20 PM   #2
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
can U send many pictures ?
Kenny Strong is offline   Reply With Quote
Old 08-29-2020, 03:19 PM   #3
This is the freezer door from my RM 2201. I have repaired , I think, the two little clips that hold the door onto the rod at the side of the freezer. I have to let it set-up for 24 hours before trying it out on the fridge freezer compartment. Sorry the pics are a little fuzzy, my phone is not the best.
Old 08-29-2020, 06:48 PM   #4
Utah
did U use super glue ? I use super glue on many things. to add some bulk to a bond, U can get gel, if what U have done holds; OK. I test it on a spot to see if it bonds to the plastic, a chemical reaction. I have taken a piece of plastic and glued it beside an existing broken piece to give it more working surface. ( structural integrity ).
Old 08-30-2020, 08:58 AM   #5
Thanks for the reply Kenny. I'm using a two part epoxy and I will reinforce the back part of the tangs before trying to install it.
Old 08-30-2020, 01:35 PM   #6
Utah
reinforce the good one also.
Old 08-31-2020, 07:49 AM   #7
Thank Kenny, I did reinforce both of them.
Freezer door for Dometic 2201 fridge Loriski Problem Solving | Owners Helping Owners 0 09-16-2014 12:48 PM
Freezer door for Dometic 2201 fridge Carol H Classified Archives 3 08-30-2011 11:27 AM
Dometic 2201 Temperature Performance. Oliver P Care and Feeding of Molded Fiberglass Trailers 9 08-08-2010 11:34 AM
GONE - Dometic RM 2201 fridge whole or parts Angelo F. Classified Archives 4 06-22-2009 07:36 PM
» Trailer Showcase
"CJ"
Wade the K
Burro
Jon Munn
