Dometic RM2453 door shelve reinforcement/repair - Fiberglass RV
Old 01-19-2020, 10:32 AM   #1
Dudley's Avatar
Trailer: 1998 Casita 17 SD
I have designed some 3d printed parts to repair or reinforce the damn brittle shelves in the door of Dometic RM2453 fridges. These are glued on and should help the shelves from breaking. If you have to replace these shelves , the cost is crazy high and the new ones will not last much longer than what you had. You will have to find someone to print them(some libraries have printers or check craigslist or Kijiji) I printed in PLA plastic and used 100% fill. They take about 5-6 hrs for a set of 6 to print. The needed files areHERE
and are under the 'Things Files" tab
Old 01-19-2020, 10:51 AM   #2
A shelf broke on my RM2510. I fixed it with a piece of aluminum and epoxy from Rona. It has held up now for years.
Old 01-20-2020, 11:46 AM   #3
francene's Avatar
Trailer: 13 ft Compact II
Good idea for that repair, Glenn! Thanks for the tip.
francene is online now   Reply With Quote
Old 01-20-2020, 12:17 PM   #4
Trailer: Escape 2013 19 ft
Excellent fix Glenn ! Pat
LindaandPat is offline   Reply With Quote
Easy cedar shelve in closet Mcmarkrazz Modifications, Alterations and Updates 2 11-02-2013 07:50 PM
frame reinforcement Scott S. Modifications, Alterations and Updates 16 04-20-2011 12:03 AM
Screen door reinforcement DianeP Modifications, Alterations and Updates 1 09-12-2006 03:47 PM
