Door hinges \ lock for Trillium - Fiberglass RV
Old 01-21-2018, 05:23 PM   #1
Trailer: Trillium
A newbie to this site but a proud owner of a 1977 Trillium 4500. We want to change the outside door hinges and get a new door handle\lock. Can anyone offer any suggestions to help?
Thanks.
Michael D.
Michael D Lad is offline   Reply With Quote
Old 01-21-2018, 05:50 PM   #2
Raz
Raz's Avatar
The hinge is a kason 139 with a 3/8" offset. Years ago I bought spares from McMaster Carr
http://www.fiberglassrv.com/forums/f...red-49552.html
But in Canada you might try these folks.
Trillium Trailer Parts | Trillium Trailers
The door lock is a Bargman L300. No longer made and very expensive on eBay. You might try cleaning what you've got.
Old 01-22-2018, 06:55 PM   #3
David Tilston's Avatar
It is actually an L400, on a 4500, and post 1977 1300's. The change on the 1300's happened somewhere between serial numbers 5121 and 5622. There is a rather large gap in the list.
http://www.fiberglassrv.com/forums/f...tml#post591982
I have seen them advertised for $800 cdn.
This one is "only" $500 cdn:
https://www.ebay.ca/itm/NICE-CHROME-...cAAOSw05taT9Ni
This one is being sold by one of our members for $400 cdn. In Calgary too. I should give OJ a call:
http://www.fiberglassrv.com/forums/f...tch-83722.html
If you plan to replace the door latch with something else, then maybe take a look a these threads:
http://www.fiberglassrv.com/forums/f...ark-51845.html
http://www.fiberglassrv.com/forums/f...ers-83011.html
Old 01-22-2018, 10:43 PM   #4
Trailer: Trillium
David..
Thanks for the info.. But if it's a L300 on a 1975 Trillium, will the same Trimark work as a replacement??
Chris from Comox..
Chris from Comox is offline   Reply With Quote
Old 01-22-2018, 10:46 PM   #5
Originally Posted by Chris from Comox View Post
David..
No.
Old 01-23-2018, 06:05 AM   #6
Trailer: Boler Voyageur 1977
Quebec
Originally Posted by David Tilston View Post
No.
These are hand made. I'm pretty sure the aluminum cover plate could be made to any size at minimum added cost. I just won't be as plug and play as the standard one, some fitting will be required on your side.
wire is offline   Reply With Quote
Old 01-23-2018, 03:05 PM   #7
Trailer: Trillium
David..
Is there any sort of replacement for the L300 on a 1975 Trillium and if so have you any info that you can share on this topic??
Chris from Comox..
Old 01-23-2018, 03:44 PM   #8
David..
Chris, I am sorry to say that there is no compatible replacement. Phillip is correct in that the procedure to install a Trimark latch in the hole of an L300 should be similar to the L400 procedure. Basically cover the larger hole with a plate that has a cut out for the new latch.
This company claims to have a replacement for an L300:
https://www.rvautoparts.com/AP-Produ...SABEgLGb_D_BwE
Maybe also look at these threads:
http://www.fiberglassrv.com/forums/f...ent-58136.html
http://www.fiberglassrv.com/forums/f...ium-50835.html
I hope that helps.
Old 01-24-2018, 01:25 AM   #9
Trailer: Trillium
David.. Thanks for clearing this up for me.. While my forte is wood, I do have some experience shaping aluminum and will give it a try when needed ;-)
Chris from Comox..
trillium
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
