door locks - Fiberglass RV
Old 06-04-2018, 07:53 PM   #1
R A Mar's Avatar
Saskatchewan
door locks
Is anyone familiar with this type of door lock? I think it is original to my '72 Boler and I would like to know if and how I can lock the door from the inside.
Rick
R A Mar is offline   Reply With Quote
Old 06-04-2018, 09:18 PM   #2
That is pretty much the old Scamp latch,(similar) in your case the outside handle is a typical pickup truck topper handle.
The Scamp latch has a hole drilled in it in which a pin is placed to lock it from inside to prevent moving the handle. An 1/8" hole in the right place will do the trick.
Old 06-05-2018, 06:06 AM   #3
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
There should be a hole already drilled into the housing on the top of the box near the three mounting screws. I thought the hole was part of the handle manufacturers original configuration. The previous owner of our Scamp had a cotter pin attached to a short piece of cord to keep the pin attached to the handle so you could "lock" the door and not have to search for the pin.
bill (not laura)
"All that is gold does not glitter,
not all those who wander are lost..." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Old 06-05-2018, 07:08 AM   #4
door locks
I have heard replacement latches from Scamp lack the hole and pin. Easy enough to add. On new builds Scamp supplies a wire pin attached to one of the mounting screws with a short length of chain. (Make that past tense- new Scamps now have a conventional RV lockset with paddle handle.)
The outside handle is a standard square shaft used in a variety of applications, including pick-up caps, garage doors, and old-fashioned delivery trucks. I found garage door handles in both T and L configurations to fit my Scamp at a hardware store. In the end I located a contoured handle just like OEM on the shelf at a local RV shop. The shaft has to be cut to length, based on the thickness of the door.
Old 06-05-2018, 09:49 AM   #5
As you know...
That wire pin , along with the latch itself, is now a thing of the past, they now use a standard RV latch and a new hinge design along with a new mold for the door and the new gasket.
Door locks Rev. Lee Cook Problem Solving | Owners Helping Owners 9 12-11-2021 06:35 AM
Bargman door locks Scouter Dave Problem Solving | Owners Helping Owners 7 09-19-2014 12:47 PM
Bargman L300 door locks Roger C H Problem Solving | Owners Helping Owners 11 08-12-2011 04:21 PM
