Double Rotating Waste Water Flange - Fiberglass RV
Old 07-10-2020, 12:58 PM   #1
Trailer: Casiti SD 17'
South Dakota
I ordered a replacement rotating flange with 3" black water and 1 1/2" grey water and 3" with lugs for the hose bayonet connector. I didn't notice until it was almost installed that there were no lugs for the bayonet connection on the new fitting. I rechecked the catalog which confirmed that I had ordered the correct fitting. I proceeded to make the old one work and now I would like to know how to make the new one work. Is there an adapter that can be welded on? I've never seen a fitting with a smooth pipe connection like this one.
Harrison
HarrisonP is offline   Reply With Quote
Old 07-10-2020, 01:17 PM   #2
AC0GV's Avatar
Wisconsin
Picture?
Originally Posted by HarrisonP View Post
I proceeded to make the old one work and now I would like to know how to make the new one work. Is there an adapter that can be welded on? I've never seen a fitting with a smooth pipe connection like this one.Harrison
A picture may help get an answer. (even a cut and paste from the seller?)
Can you use the part from your old flange on the new valve?
https://www.etrailer.com/dept-pg-RV_...-Adapters.aspx
Old 07-10-2020, 02:48 PM   #3
South Dakota
I don't know how to find the url of my photo or the photo on the web site.
Old 07-10-2020, 07:01 PM   #4
South Dakota
https://photos.app.goo.gl/MXF3EeVFCkjkjTPx6
Old 07-11-2020, 07:35 PM   #5
Trailer: 28' Bigfoot Silver Cloud
Woodstock, IL
From what you have, it appears either of the first two adapters pictured in the eTrailer link would work by using pvc glue. They are made to complete a straight connection like you have.
Old 07-11-2020, 08:00 PM   #6
South Dakota
Thank you. I had not gone to that link for some reason. They are exactly what I need.
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
Trillium 4500 City Water Flange Laurie Problem Solving | Owners Helping Owners 3 07-04-2012 01:13 AM
Butyl tape under flange, then rivets or screws, + sealant ??? Guy, Boulianne Problem Solving | Owners Helping Owners 7 06-29-2010 07:09 AM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
