Double sided tape - Fiberglass RV
Old 08-18-2022, 06:04 AM   #1
Trailer: U-Haul
SE Pennsylvania
Double sided tape
There are a few items I want to hang inside my double shell trailer (smooth gelcoat inside).
3M VHB double dided tape has been mentioned here on the forum. A bit of research reveals there are many varieties of the tape. Different thicknesses for smooth or rough surfaces. Different adhesives for use on various materials and temperatures. The options are a bit overwhelming.
Do any folks here have experience with this tape? Is there one part number that has become the standard for our trailers?
Craig D. Thompson is offline   Reply With Quote
Old 08-18-2022, 06:30 AM   #2
mszabo's Avatar
Trailer: U-Haul VT16
Many types are available. Personally I’d use a tape that has the 3M label on it. Doesn’t mean it wasn’t made in china but, it is a high quality product.
May $.02
Old 08-18-2022, 07:01 AM   #3
Shocksll's Avatar
NC
I use this to hold up a shelf inside my camper and my solar panels on the roof. So far so good.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Steve Lineberry - Based out of Charlotte, NC and part of Team Cragmama
2021 Casita Heritage Deluxe 17'
2018 Toyota Highlander AWD XLE Anderson WDH
My Casita YouTube videos
Shocksll is online now   Reply With Quote
Old 08-18-2022, 09:20 AM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
I've been using 3M RP45 on my products for 15+ years. It's 0.045 inches thick, rated for exterior use (aka bathrooms) and has a peel strength of 20 lbs per square inch when allowed a full 72 hour cure time prior to being loaded. Good to 200F and closed cell foam.
Charlie Y
Old 08-18-2022, 01:01 PM   #5
AC0GV's Avatar
Wisconsin
I use this VHB
Now if some one can just tell me how to get the backing ofF! Always clean BOTH surfaces with cheap alcohol before application.This looks like a different listing for the same product as above.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-19-2022, 12:26 PM   #6
Trailer: Casita SD
Some RVers who use it to secure solar panels to the roof claim that it lasts longer when a sealant is applied along the edges of the tape, after it is stuck in place.
Apparently, the sealant helps keep the foam backing from degrading over time, and discourages moisture from seeping in between the tape adhesive and mounting surface.
JoelInTexas is offline   Reply With Quote
Old 08-19-2022, 02:37 PM   #7
Shocksll's Avatar
NC
Agreed, i added dicor and eternabond to mine.
B75461D7-9DA0-4DFE-8AF5-56D5306B8D14.jpg   D9857BC6-43E6-44FD-8F9E-7C4933C78A8A.jpg
Old 08-19-2022, 10:28 PM   #8
John in Santa Cruz's Avatar
Mid Left Coast
for small interior stuff like hooks, the 3M "Command" strips work great on a slick surface like gel coat.
Old 09-04-2022, 01:34 PM   #9
Trailer: 2002 Scamp 13' Std, Honda CRV
Has anyone attached a keder rail for an awning with VHB tape? I plan to use the Sailrite plastic flanged awning rail with the keder rope awning. I really don't want to drill holes so looking at VHB or gluing. I read somewhere that if you need to remove the VHB it can peel apart the fiberglass..? Anyone have experience using VHB for this application?
Shannon Thompson is offline   Reply With Quote
Old 09-04-2022, 10:10 PM   #10
tractors1's Avatar
I use many rolls of 3M RP45 VHB tape on my products; exterior rated to 200F, 20 lb per square inch peel strength when cured 72 hours, and 0.045 inches thick.It is easily removed using fishing line like a saw to cut the inner foam in half. Thereafter, roll the tape up like a tootsie roll to remove. Any residue can be removed with acetone with no damage to fiberglass.
Charlie Y
Old 09-04-2022, 10:17 PM   #11
"...fishing line like a saw and roll like a tootsie roll..." That is scathingly brilliant! What a great tip. Thank you! Very helpful...on with the project.
Old 09-05-2022, 04:09 PM   #12
theresa p's Avatar
Hi Shannon---yes, I used the VHB tape to secure my Keder rail from Sailrite, and it has been in place since 2018. Never had any issue with it separating from the fiberglass and I have taken it over 10,000 kms with it in place.
Old 09-05-2022, 05:32 PM   #13
Thank you, Theresa, appreciate your feedback. Curious -- what did you use for an awning? I'm looking at 1) sewing something myself from Sunbrella; 2) modifying a camping tarp; 3) ordering something from Marti's awnings (https://www.martisawnings.com/).
Happy trails.
S.
Old 09-05-2022, 09:50 PM   #14
tractors1's Avatar
fyi, VHB is short for Very High Bond in 3M speak. Same stuff is now used to build semi truck trailers; the walls are taped to the frame, so there are no more rivets dimpling those walls. Makes it easier to overlay those gorgeous graphics.
Charlie Y
Old 09-05-2022, 10:03 PM   #15
Mid Left Coast
FWIW, my kid used VHB to attach the aluminum skin panels to the welded aluminum frame of the expedition camper he's built...
truck with frame,
skins being attached,
its been road tested at freeway speeds in heavy gusty winds, and so far has held up just fine.
Old 09-05-2022, 10:32 PM   #16
truck with frame,
Wow - that is impressive...I will never drill another hole! This has all been very useful. My next project is to add solar to the Scamp -- including a panel on the roof. Thanks for all the feedback.
Old 09-05-2022, 11:28 PM   #17
tractors1's Avatar
Big budget for clamps! Those aren't cheap ones - probably close to the cost of the skins....
Charlie Y
Old 09-10-2022, 02:59 AM   #18
Mid Left Coast
Probably borrowed.... My kid is working as a post-doc researcher in Geology at Oxford, mapping earthquake faults in central Asia, so has to get by on a tight budget.
2 Sided Tape Craig D. Thompson Problem Solving | Owners Helping Owners 3 07-21-2021 11:06 AM
Double sided glazing tape Linsey B Problem Solving | Owners Helping Owners 3 06-01-2019 09:13 AM
Best double sided tape Steve Hammel Problem Solving | Owners Helping Owners 29 09-14-2018 11:58 AM
Removing double sided tape. Zachs Problem Solving | Owners Helping Owners 7 04-17-2017 11:22 PM
Butyl tape - putty tape? Janb313 Problem Solving | Owners Helping Owners 10 03-23-2013 10:21 PM
