Electric tongue jack - Fiberglass RV
Old 06-08-2025, 06:56 AM   #1
Trailer: Scamp 16'
We have a 16' Scamp. What brand electric tongue jack would members recommend? Thank you. Bob
Bob Greene is offline   Reply With Quote
Old 06-08-2025, 10:54 AM   #2
AC0GV's Avatar
Wisconsin
Scamp electric jack
Almost anything rated for 3500 lbs will work, also need to have an emergency crank for when the battery is dead.
This is the one from Scamp direct.
https://www.scamptrailers.com/produc...ic-tongue-jack
This is the one I have, and I have sheared the pin in it by running it to far.
https://www.amazon.com/dp/B09T2V1V6L...d_asin_title_1
Old 06-08-2025, 11:26 AM   #3
Trailer: Scamp 16'
Thank you very much for your reply. I decided to go with the one that Scamp sells and then questioned whether or not u can use the wheel with the electric jacks.
Old 06-08-2025, 11:53 AM   #4
AC0GV's Avatar
Wisconsin
Only at home...
...in my driveway. It hangs to low for road use, and many gas station entrances.
Old 06-08-2025, 12:15 PM   #5
Trailer: Scamp 16'
I understand it might be a problem to leave a wheel on but my question is just whether or not a wheel can be used in place of the flat pad.
Old 06-08-2025, 12:26 PM   #6
AC0GV's Avatar
Wisconsin
Yes it's part of my security
I roll the Scamp head first into the parking space with the wheel and then put the pad back on then drop the stabilizers. My hope is that it will at least slow down any theft attempt.
Old 06-14-2025, 10:39 AM   #7
Trailer: Casita 17 SD
Alabama
Do not use UF electric tongue jack
Use any brand but UF, which seems quite popular. I have gone through 3 of them. Yes, I am a slow learner. One was on my 17’ Casita when I bought it. It went out at 3 years. The next one lasted a year and the third one is headed for the trash heap now, failing shortly after the warranty expired. The problem? In each one of them, the “up-down” switch failed. In the last two, the terminals on the switch had corroded and turned to dust (after only a year.) It’s probably what happened to the first one, though I didn’t check. And, no, the jacks were never submerged in salt water.
Joemcameron is offline   Reply With Quote
Old 06-14-2025, 01:45 PM   #8
Trailer: Scamp 16'
Once again I thank everyone who has responded. I do, however, still question if there are power tongue jacks that can accept a wheel in place of the flat rectangular or round plate that touches the ground. Maybe all electric tongue jacks allow either a wheel or plate.
Old 06-14-2025, 02:14 PM   #9
Gavin's Avatar
Ca
I've been using the Barker VIP 3500 for the past five years and love it. It's high end and very well engineered. It's nice that you can rotate the head in case you need more room for your back trunk to open and close.
https://amzn.to/44i2Vvi
Gavin is offline   Reply With Quote
Old 06-14-2025, 02:30 PM   #10
Trailer: Casita Liberty Deluxe
LA
My Barker is over 10 years old, I was repainting it because it was yellowing and Barker sent me a batch of the stickers for free.
Great company and product.
daveandalice is offline   Reply With Quote
Old 06-15-2025, 08:40 AM   #11
Trailer: '75ish SurfSide 14'
Manitoba
One of the pics in the ^^ link to the Scamp jack shows it's components. Looks like the plate is mounted on the tube via a pin. So long as the wheel has the same mounting system it should be doable. [Without seeing one, I assume that IF modifications to any wheel attachment are needed, it should be a fairly straightforward process ... especially if you have a grinder and welder on hand.]
owenmaura is offline   Reply With Quote
Fixing bubble level on Electric Tongue Jack! Michael Pupeza Problem Solving | Owners Helping Owners 1 09-24-2010 05:10 AM
Electric Tongue Jack Opinions: Atwood vs. Ultra Fab Jane P. Care and Feeding of Molded Fiberglass Trailers 31 01-16-2010 02:41 AM
Electric Tongue Jack Donna D. Problem Solving | Owners Helping Owners 23 02-15-2006 07:26 PM
