Considering changes to our outside
electrical connection. We currently go to a water tight box with a surge protector and then into the trailer. Bugs can get in but not many just tired of
leaks after resent storms.
With pig tails inside:
WELLUCK 15 Amp 125V AC Power Inlet Port Plug with Integrated Dual 18" Extension Cord, NEMA 5-15 RV Flanged Inlet with Waterproof & Back Cover Y Splitter Cable, 2 Pole 3-Wire Shore Power Plug for Boat
----would plug surge unit into one pigtail and trailer into it and use other pig tail for
battery mender charging of
battery. They they also have a single pig tail unit.
Hard wired in:
WELLUCK 15 Amp Flanged Inlet 125V, NEMA 5-15 RV Shore Power Inlet Plug w/Waterproof and Back Cover, 2 Pole 3-Wire AC Port Plug,
Generator Male Receptacle for Marine Boat RV Shed
Electrical Extension
----would cut end of surge unit wire it to plug and then plug trailer into surge unit as well as cord for
battery mender when not using outer powered items.
Has anyone tried this?
The make smaller unit even a metal one but they would fit through current hole.
