Electrical Wiring diagram for Trillium 4500 1977 - Fiberglass RV
Old 05-25-2022, 09:33 AM   #1
QC
Hi i am new to the community. I am looking for the detail electric diagram 120v and 12v) for a trillium 4500 1977. Many thanks ! RayLes
RayLes is offline   Reply With Quote
Old 05-25-2022, 10:13 AM   #2
David Tilston's Avatar
The document center is where you can find it:
https://www.fiberglassrv.com/forums/...do=file&id=321
OK, after looking at it that is just wire color codes.
This one is the wiring diagram:
https://www.fiberglassrv.com/forums/...do=file&id=134
Old 08-08-2024, 01:19 PM   #3
Trailer: 1979 Trillium 4500
Manitoba
The wiring diagram in the document center is for a Trillium 1300, not 4500. Given that the power center is on the opposite side of the trailer on the 4500 vs 1300, it just isn't really valid for the 4500.
Does anyone have such a diagram, but for a 4500?
spidermoore is offline   Reply With Quote
Old 08-08-2024, 10:10 PM   #4
John in Santa Cruz's Avatar
Trailer: Escape 21, behind an '19 Ferd Expedition
Mid Left Coast
wiring diagrams for any given trailer are only approximate guidelines. things are often wired ad-hoc even within the same model year
Old 08-10-2024, 08:29 AM   #5
Trailer: 2013 Escape 19
The Mountains of NC/SW Desert of UT
And prior owners have had almost 50 years to make changes.
And the 1300 diagram is not laid out with actual locations. I bet the 4500 wiring is nearly identical. I think they used a similar POS electric control center. One of the best things I did to my 1977 Trillium was replace that control center, and add a removable power cord.
FWIW: All my knowledge about Trilliums came from others, in particular Dave Tilston and Randy Bishop. The upper right on the home page, click on manufacturers, then select Trilliums. You will get access to all of the threads on Trilliums.
Check my Trillium Project Page: https://www.facebook.com/Bills-1977-...dmin_todo_tour
Old 03-19-2025, 12:38 PM   #6
Trailer: 1977 Trillium Surfside
AB
Where is the power centre 1977 Trillium Surfside
Hi all: my new furnace is on the fritz and I suspect it's a breaker issue (I know nothing about wiring, circuits etc.) - I can't locate the circuit panel in my trailer. I've taken a few things apart (the panel under the sink for example. Can someone please point me in the right direction? Thanks!
Emo1975 is offline   Reply With Quote
Old 03-19-2025, 12:54 PM   #7
Mid Left Coast
On a Casita, the fuse panel is behind a pop open panel on a brown box like one one seen here at the bottom of this bench support.
this is the Casita fuse panel thats behind the pop open panel on that brown box
the fuses are for DC devices like the fan in your furnace, while the circuit breakers are for 120VAC devices like air conditioner, any outlets.
now, my Casita was a 2004, your Trillium is a lot older than that so it might have a completely different sort of setup.
electrical, trillium
Wiring diagram trillium 4500 Bobby Kirk Problem Solving | Owners Helping Owners 4 06-27-2019 11:09 AM
Bigfoot Electrical Wiring Diagram 1983 17B trailer keenie82 Problem Solving | Owners Helping Owners 13 07-27-2017 06:40 PM
Trillium 1300 wiring diagram needed. William Neufeld Problem Solving | Owners Helping Owners 1 07-08-2008 12:07 PM
Wanted:Trillium wiring diagram Mikey Problem Solving | Owners Helping Owners 1 09-01-2007 05:07 PM
