Fiberglass body with pin holes - Fiberglass RV
Old 02-27-2021, 12:19 PM   #1
Trailer: casita freedom
Last summer i had a blow out on my casita 17ft trailer. The tire flapped around for a while until i found a place to stop. The side of which my tire that was. Flapping put tiny chips in my fiberglass. Can some tell me how to fix these tiny chips.
Thank u
darlene vogel is offline   Reply With Quote
Old 02-28-2021, 10:45 AM   #2
neauone's Avatar
Put up some photos of the damage. Fiberglass filler should do the trick.
neauone is offline   Reply With Quote
Old 02-28-2021, 10:54 AM   #3
GOB
Trailer: Scamp 19
Pin holes
If you a talking chips in the gel coat there is a product called "MagicEzy" that looks like it should work well. I got some but have not used it yet.
GOB is offline   Reply With Quote
Old 02-28-2021, 11:01 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
For repairing non-structural damage, the most basic steps include cleaning and roughing up the surface with a grinder and/or 60-80 grit sandpaper, then cleaning the surface again with alcohol or acetone. Shallow damage to the gelcoat can be repaired with body filler.
If the chips are visible, cosmetic in nature, there is work involved in achieving a visually appealing result. This involves filling and sanding with finer and finer grit sandpaper, then applying matching paint or gelcoat.
Old 02-28-2021, 12:19 PM   #5
Thanks to all
Old 02-28-2021, 12:28 PM   #6
I went to a marine dealer and picked up a tube of gel coat repair
It was inexpensive ( $7 a tube ) and easy to apply
They use it to repair fiberglass boats that get chipped
Old 02-28-2021, 12:35 PM   #7
Thank u
How to seal holes between frame and fiberglass body? Fredomatic Care and Feeding of Molded Fiberglass Trailers 6 07-22-2017 11:42 AM
Screw holes. How do I repair the old screw holes around the Window. BeckyK Care and Feeding of Molded Fiberglass Trailers 5 07-17-2017 07:03 PM
Volvo European 7-pin to US 7-pin EllPea in CA Towing, Hitching, Axles and Running Gear 51 09-18-2015 05:05 AM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
