Fiberglass pulling away form bottom edge - Fiberglass RV
Old 05-26-2021, 08:04 PM   #1
Trailer: Palomino
Maine
Hello, I bought a used fiberglass Palomino 27' trailer and after a couple years the fiberglass is pulling away from the bottom on one side. It looks like it was held on with a bead of caulk on the outside. I can easily pull it away from the wall so I suppose water got up in there over the winter and debonded it. I know I can just run a bead of caulk along the bottom to hold it to the side but is there something I can do that would be better? Like glue it first and try some moulding along the bottom edge?
Orerockon is offline   Reply With Quote
Old 05-26-2021, 10:19 PM   #2
Not a molded FG trailer. Sounds like the typical composite wall design. Read up on siding delamination, its a very common problem without quick and easy fixes. It is NOT held on by a bead of caulk. It is glued to a substrate under the fiberglass.
Some of us here migrated from laminated fiberglass walls to molded fiberglass, after dealing with such problems.
https://www.coachspecialists.com/blo...v-repair-shop/
We plan on removing snow form our Scamp! BatDude Modifications, Alterations and Updates 6 11-22-2015 02:02 PM
A huge thank you to everyone on this form!! Cheyanna83 Problem Solving | Owners Helping Owners 2 07-19-2015 05:43 PM
buying a camper form out of state Ray Cover Money Matters 3 06-16-2013 08:57 PM
removing paint form fiberglass ScottG Problem Solving | Owners Helping Owners 7 09-15-2010 03:38 PM
