Fiberglass Woes - Fiberglass RV
Old 05-26-2020, 02:11 PM   #1
SaskCamper's Avatar
Trailer: Triple E
Saskatchewan
Fiberglass Woes
Not surprisingly, the Fiberglass down under by the frame is cracked on my Triple E SurfSide. Likely because at some point in it’s nearly 50 year lifespan, someone overloaded this little camper, or hit a pothole, or both.
Based on the photo I’ll add, can anyone with experience with this weigh in? I’ve never done Fiberglass before, let alone reinforced it. I feel like this type of damage, in addition to what looks like a major roof repair might be better left for professionals. Open to suggestions.
SaskCamper is offline   Reply With Quote
Old 05-26-2020, 02:17 PM   #2
If you need to have somebody else do the repair, I suggest a boat repair place.
Old 05-26-2020, 02:26 PM   #3
Steve Hammel's Avatar
Trailer: Trillium 4500
Show the photo. Fiberglass isn't that hard to work with. It only requires expertise over common sense where the fix is visible. If the required fix is out of view read up on it and give it a shot.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe, Casita 16, Casita 17, Scamp 13' with bath.
Old 05-26-2020, 04:24 PM   #4
SaskCamper's Avatar
Trailer: Triple E
Saskatchewan
Sorry, I thought I had included pictures.
Here they are:
Old 05-26-2020, 04:25 PM   #5
SaskCamper's Avatar
Trailer: Triple E
Saskatchewan
Sorry they are sideways. How do I fix that?
I definitely don't have expertise, but my common sense tells me the problem underneath needs fixed and should be reinforced properly.
Old 05-26-2020, 04:48 PM   #6
FRED SMAILES's Avatar
Trailer: 13 ft Boler
I don't really see much in the wheelwell 'cept a small crack. Would need better images to comment, but the roof is actually quite a simple fix, it will take work,, but is simple.
You haven't stated what the ceiling is covered in but that would have to be
Removed back 5ish inches from the repair. Take the repair that is on the roof wrap it tightly with 6mil poly and place it under the hole supporting it so the panel takes on the shape of the roof grind back the edges of the fglass so all the gelcoat is off and the glass is tapered down to the backer panel.
Install several layers of glass to replicate original thickness. Allow to set and grind off the high points and bondo to shape.
Remove the support rough up the ceiling and another coat or two of glass
Gring smooth and replace ceiling finish.
Lots a YouTube to learn fglassing out there.
Spend a little time leaning to work with glass before climbing a ladder to learn on your little trailer!
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
FRED SMAILES is offline   Reply With Quote
Interior Electrical Woes Terra Sitah Problem Solving | Owners Helping Owners 5 10-10-2016 05:06 PM
water heater woes Dan B Problem Solving | Owners Helping Owners 16 08-01-2011 06:40 PM
My turn to cry... water woes Deb in MN Problem Solving | Owners Helping Owners 3 04-26-2006 04:38 PM
Propane woes Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-05-2002 04:50 PM
