Filling stripped holes and re-drilling? - Fiberglass RV
Old 09-06-2020, 11:00 AM   #1
ZachO's Avatar
Trailer: Sasquatch
Montana
I’m sure there’s an obvious solution.
I just replaced the piano hinge on my front window guard, and one of the latches has stripped screw holes. These holes line up with the hole in the rock guard, and are nicely symmetrical, so I’d like to keep them where they are.
What product can I use to fill them, then drill and use them again? I’ve tried the idea of stuffing match sticks or something in oversize holes and I don’t prefer it...
Thanks.
Old 09-06-2020, 11:17 AM   #2
Trailer: 1978 Boler
Almonte, Ontario
Stripped holes
If the awning is fibreglass, mix an epoxy (five minute) and fill the holes, cure and redrill. Another solution would be to use T-nuts with the gripping teeth flattened and the existing holes drilled out to accommodate.
Nicolas is offline   Reply With Quote
Old 09-06-2020, 11:48 AM   #3
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
what is behind the glass face ?
Kenny Strong is offline   Reply With Quote
Old 09-06-2020, 11:50 AM   #4
Raz
Raz's Avatar
When I had to reset the hinges on my Trillium, I used an epoxy paste called PC 11 and injected it into the holes. Worked well. Holes that go all the way through need to be backed. I used scrap sheet metal.
ID:	137289Click image for larger version
ID:	137290Click image for larger version
Old 09-06-2020, 11:54 AM   #5
ZachO's Avatar
Trailer: Sasquatch
Montana
Alright, thanks!
Behind the fiberglass there's wood, which is great for good holding strength. Until it gets stripped...
These got stripped because the piano hinge had been failing for years, so the rock guard was sagging, resting more and more heavily on the latch, finally pushing it down and forcing the screws out.
Raz I'm guessing that syringe didn't come with the epoxy? I'll see what the local hardware store has.
Old 09-06-2020, 12:13 PM   #6
Utah
Use Raz's idea. then Nicolas's t nuts with the barbs into your existing wood backer.
Old 09-06-2020, 12:52 PM   #7
Raz
Raz's Avatar
Originally Posted by ZachO View Post
Alright, thanks!
No, the syringe was seperate but the hardware store should have them. Woodworkers use them for glue.
Old 09-06-2020, 01:45 PM   #8
ZachO's Avatar
Trailer: Sasquatch
Montana
Alright, thanks.
Hardware store is closed till Tuesday. I was hoping to do it today so it had time to cure before the cold front and rain/snow moves in, but it looks like I'll have to wait until after!
Old 09-07-2020, 03:51 AM   #9
Raz
Raz's Avatar
I thought the screws were held by the fiberglass. That was the case with my door. If the wood is what really holds the screws then if you have acess to the back, I would use bolts with a washer between the nut and the wood. If no access, I would drill the holes out and fill with a glued dowel. Be aware, many hardware store dowels are metric.
Old 09-07-2020, 07:23 AM   #10
Trailer: 2013 Escape 19
Its all about what is behind the fiberglass. Chances are, the screws are not threaded into the fiberglass, they are threaded into whatever is under it (likely wood). Rotten wood is usually the culprit. Patching the fiberglass alone is not the solution.
Old 09-07-2020, 08:26 AM   #11
ZachO's Avatar
Trailer: Sasquatch
Montana
Yeah there's wood just behind the fiberglass. I don't have easy access to it from the inside, though. It would require taking the interior walls out. I don't have a completely clear picture of how Bigfoot constructed these, but there's a lot of wood. I don't think there's a full sheet of plywood behind all the fiberglass, completely boxing in the trailer, but there's a lot of wood framing all the windows, door etc. The screws for that latch are a couple inches long.
There may be some rotted wood, but it's the sagging rock guard that caused this issue. Probably as it enlarged those screws holes with all the pressure, some water started getting in there. But the latch on the other side is solid. Maybe dowels are the way to go.
I don't see t-nuts working here, since I'd like to keep the latch flush to the fiberglass, but they are exactly what I need for my upper fridge vent. Almost every one of those holes is stripped, and it's unfortunately an area I need to access fairly often, so they're only getting worse. Screws directly in wood aren't set up for repeated removal, so dowels wouldn't be great there. A metal threaded insert is perfect. But yes, for this latch, which hopefully I never need to remove again, dowels will be great.
Old 09-07-2020, 09:27 AM   #12
Raz
Raz's Avatar
There are some who would fill the holes with epoxy and thread the screws in and let the epoxy cure. The problem is if you ever have to remove those screws in the future you could end up with stripper heads, broken screws, ect. That's why I suggested the dowels. A glued dowel is as strong if not stronger than the original wood and if you use the correct size pilot holes, the screws will go in easy, and if the need be, come back out easy. And if the problem repeats, the dowels can easily be drilled out and replaced. Ever try to drill out a broken screw in wood?
Old 09-07-2020, 09:46 AM   #13
ZachO's Avatar
Trailer: Sasquatch
Montana
I don't think I have. I've tried to dill out broken bolts in metal, but not a screw in wood. It doesn't sound like fun, or like it would even work without a lot damage to the wood around it...
No, I was going to inject epoxy and let it cure, then drill, like you had initially recommended. But I think the dowel idea is even better for this.
Old 09-07-2020, 09:52 AM   #14
Take a look at Git-Rot as an alternative.
Old 09-07-2020, 11:30 AM   #15
Raz
Raz's Avatar
My trillium and I suspect other trailers use plywood spacers around the windows which unfortunately eventually rot. If thats the case here then there is no permanent fix without replacing plywood. If you think your wood is rotting then Glenn's suggestion could be a good temporary fix until some future date when you've got the time. Like when Covid 23 arrives.
https://www.boatlife.com/news/how-to...o-use-git-rot/
Old 09-07-2020, 11:32 AM   #16
Utah
I like the threaded insert you talked about. If a threaded insert has a screw with a nut stopping it from turning into the insert is turned into the hole with the glue already placed in the opening it can set up in the glue. the screw and the stop nut can be waxed to keep the glue from adhering to the screw threads.
put a wrench on the stop nut to brake the bond, unscrew the screw.
Old 09-07-2020, 01:06 PM   #17
Trailer: 1993 CASITA 16SD
White JBWeld has worked for me in the past.
CASITA BANANA is offline   Reply With Quote
Old 09-07-2020, 02:31 PM   #18
Trailer: 1978 Boler
Almonte, Ontario
Ahhh! Kenny B beat me to the waxed bolt suggestion. This is suggested for implanting bolts into fibreglass and epoxied holes in wood. Jus make sure that you wax and then lightly twist the wax into the threads. Did this by mistake with a thick layer of wax and the bolt was too loose afterward.
Old 09-07-2020, 02:38 PM   #19
Wood dowels work well
Agree with your method. Ive done this many time restoring old houses with stripped door/cabinet hinge screws . Sometimes ill pilot out the hole to match the dowel.
Galoolie is offline   Reply With Quote
Old 09-12-2020, 12:02 PM   #20
Trailer: Lil Bigfoot 1988 B13.5
For my front window cover I replaced all the screws with rivnuts and bolts. A much more secure mount.
Drtriumph is offline   Reply With Quote
Filling metal holes morgynm Care and Feeding of Molded Fiberglass Trailers 17 05-30-2016 06:59 AM
Filling Screw and other small holes in fiberglass frankcfx Modifications, Alterations and Updates 13 02-22-2016 09:09 AM
Solar Panel Installation - no drilling holes carlkeigley Modifications, Alterations and Updates 39 09-13-2013 03:42 PM
Tips for Drilling Holes in Fiberglass Lil M. Modifications, Alterations and Updates 33 08-17-2012 05:46 AM
Stripped Screw Holes Quint362 Problem Solving | Owners Helping Owners 15 03-12-2012 08:19 PM
