Fixing boler sag/door sag - Fiberglass RV
Old 01-28-2024, 11:02 AM   #1
Trailer: boler 1978
I know this one has been beaten to death...
My 78 boler is sagging and the door is not sealing right anymore. Its definitely the shell sagging as the big cabinet has worked its way about 2 cm from the wall and the kitchen cabinet supports are slightly coming forward. I'm planning on putting that all back and adding some strength to it.
This is my main question: Whats the best/easiest way to get it to the right shape before redoing all the fasteners and reinforcing it?
I was thinking a 2x6 across the length of the ceiling inside propped up with a car jack till I get the right shape?
As for adding strength. I was going to use double rivet L brackets inside the big cabinet both sides top to bottom as well at front and back bench seats.
I rebuilt the kitchen cabinet up top with 1/2 inch cabinet ply so its stronger. I was going to add beefier material below the counter top and bigger bolts to support the upper cabinet/roof.
I'm considering wire cable across the front bench seat with plates on the outside. Maybe across the bed as we almost never use it as a table but if I do that I would have to make it removable just in case.
Thanks!
kip22 is offline   Reply With Quote
Old 02-03-2024, 11:07 AM   #2
steve67's Avatar
Trailer: '79 Boler
on Ontario
Have you checked the steel frame that is there to support the FG body? They do sometimes crack and subsequently the Boler body looses shape.
steve67 is offline   Reply With Quote
Old 02-03-2024, 07:53 PM   #3
Trailer: boler 1978
Hi Steve
My frame is in good shape. I got lucky with that. I'm the second owner. Original owner used it very little and kept it in a garage. Every couple years I crawl under and treat the frame with some rust inhibitor and a coat of paint.
I've got er mostly back to the right shape. I jacked the roof a little and used clamps and pressure to get it to where its suppose to be and re-riveted. I used double rivet L braces everywhere as it seems the singles are where it failed mostly. Once I'm done and happy with it I'll have to look at adding some more strength so I don't have to do this again soon.
Old 02-03-2024, 08:05 PM   #4
steve67's Avatar
Trailer: '79 Boler
on Ontario
I took the rivets out of mine and put in stainless machine screw/flange washer/acorn nut. Picture here:
Old 02-03-2024, 08:07 PM   #5
Trailer: boler 1978
Screws are stronger but its risky. I always use aluminum rivets. I want the rivet to fail before the fibreglass
Old 02-04-2024, 05:21 AM   #6
steve67's Avatar
Trailer: '79 Boler
on Ontario
"I want the rivet to fail"
That an interesting contradiction to what you've talked about earlier. I'd rather that nothing fail.
Old 02-04-2024, 05:28 AM   #7
JPM
Trailer: 1972 Boler 1300
I have been replacing my rivets (when needed) with these as well. No issues thus far that I can see. The flange washer spreads the load on the fiberglass better than the rivets do (in my opinion anyway).
Cheers
jp
JPM is offline   Reply With Quote
Old 05-19-2024, 11:27 AM   #8
Trailer: BOLER
AB
Do you remember the size of screw, flange, washer and acorn nut that you're using? I was thinking of doing the same to mine.
Sal H is offline   Reply With Quote
Old 05-19-2024, 02:41 PM   #9
JPM
I used # 8 Stainless Steel. The machine screws and acorn nuts are 8-32 and the screw is 1" long. Used it to replace the left inner rivet holding up the upper cabinet above the sink. It always leaked at that spot and since replacing no longer does.
Cheers
jp
Old 05-20-2024, 05:07 AM   #10
steve67's Avatar
Trailer: '79 Boler
on Ontario
JPM's suggestion will work. I used #10-32 x 1" SS flat head machine screws and, of course, 10-32 acorn nuts as they fit the holes left by the pop rivets better. I also put a bit of butyl tape under the washer for added assurance.
Old 05-20-2024, 05:22 AM   #11
steve67's Avatar
Trailer: '79 Boler
on Ontario
Photo of the product I used.
Old 05-20-2024, 06:13 AM   #12
JPM
If memory serves me right, I don't think I could get a #10 screw through the rivet hole and I didn't want to drill out the hole so went with the #8 - or maybe the #8's were what I had on hand at that time. At any rate both will work fine (as per steve67) with the #10's being a bit more robust. The butly tape is a good idea as well. I used a flat and lock washer against the acorn nut as well.
Cheers
jpm
boler
Boler Door Sag RyeNGinger Problem Solving | Owners Helping Owners 6 06-30-2022 03:27 PM
Boler door sag.... skytech Problem Solving | Owners Helping Owners 10 03-23-2022 12:26 PM
Boler Door Sag Fix Seattle Boler Problem Solving | Owners Helping Owners 7 02-29-2020 12:22 PM
Boler door sag fix help needed Michael Collins Problem Solving | Owners Helping Owners 48 02-24-2020 03:41 PM
76 Boler door sag? help! Timothy Earthnynja Problem Solving | Owners Helping Owners 28 05-21-2017 09:32 PM
