Fridge Hinge Reinforcement - Fiberglass RV
Old 06-21-2020, 09:51 AM   #1
Name: Eva and Kirk
Trailer: Casita 17 Spirit Deluxe
Virginia
Our Casita 17 SD has the three way Dometic Refrigerator. I've read about hinges breaking and at a rally someone suggested getting a reinforcement kit from Little House Customs. I am confused as this appears to be reinforcement for the top hinge and all the posts I saw indicate the lower hinge is what fails. I have the Little House Customs part in hand and installation is a little intimidating. Not sure why I should mess with the door and reinforce the upper hinge if the lower hinge is the problem. Some first hand experience on this issue would be most valuable right now. Or maybe I'm reading the instructions wrong???
Evirk is offline   Reply With Quote
Old 06-21-2020, 12:10 PM   #2
I bought two of them, and installed them on both the top and bottom hinges. And, fwiw, historically, it is generally the top hinge that would be the one to fail if it does.
And that is not the extent of potential "fridge door" failures. The inside plastic shelves on the door are also very weak and prone to breaking. They are also ridiculously overpriced to buy if you need to replace them when they do fail. Mine have too. I rebuilt and reinforced them with additional "beefing up" of the sides where the shelves slip into the mounting grooves on the door itself. That is where they break.
I added sections of 1/2" PVC pipe, with about a 1/4 radius removed, which I glued to the corners of the shelves with PVC pipe glue, and after they hardened up, I filled the hollow areas with Sika-Flex white sealant, like filling an eclair pastry. That really reinforced those corners. I also added small angle brackets under the middle of the shelves and added some screws in the sides to add additional support. I now travel with those shelves fully loaded and I have not had a problem with a broken shelf since.
Old 06-21-2020, 01:17 PM   #3
As Greg suggested, I bought two hinge reinforcement kits from LHC and reinforced both the upper and lower refrigerator door hinges on our Casita
The installation is simple and straightforward
Six years later the door on our Casita refrigerator still worked perfectly
As far as the plastic parts cracking breaking , I made the repairs with glue and some metal reinforcements- not beautiful but functional.
Old 06-21-2020, 07:10 PM   #4
Name: Eva and Kirk
Virginia
Greg and Steve
Thanks very much. This is why I just love Fiberglass RV. Great practical advice from real world experience and folks willing to share. And with PICTURES! I think I'm getting a second reinforcing part and installing them both at the same time. I really like the shelf modifications with the PVC pipe! Clever folks out there!
Thanks again
Kirk and Eva
Old 06-21-2020, 07:16 PM   #5
I broke a shelf by loading it too heavily and driving a washboard road. Fixed with aluminum edging and epoxy.
Old 06-22-2020, 10:53 AM   #6
I bought some scrap stainless at the junk yard and made hinge re-inforcements for the top and bottom.
Jon31433 is offline   Reply With Quote
Old 06-22-2020, 01:27 PM   #7
Name: Eva and Kirk
Virginia
Glenn & Jon-
Thanks, more great tips!
Eva and Kirk
fridge
Trillium Frame Reinforcement (recall) dale k General Chat 4 06-11-2013 04:31 PM
'84 Burro 13' interior floor reinforcement TomZ Modifications, Alterations and Updates 0 03-02-2013 06:18 PM
frame reinforcement Scott S. Modifications, Alterations and Updates 16 04-20-2011 12:03 AM
Bigfoot Bumper Reinforcement Tim D. Modifications, Alterations and Updates 0 04-18-2011 02:08 PM
Screen door reinforcement DianeP Modifications, Alterations and Updates 1 09-12-2006 03:47 PM
