Hey Everyone! I am at a loss here and am hoping that someone on this forum might be able to help with my issue before I head on a camping trip in 6 days.
As the
title states, the
propane function on my Dometic 3-way
fridge, RM2353 is no longer working.
Here’s the story…
The 110V and 12V functions work just fine.
Fridge cools down great and freezer freezes, no issues. However, when switching to the
propane function, it no longer cools down at all.
The burner
lights up and holds a flame, but the flame seems to be weak. While lit, the burner flame appears to toggle between “full flame” and “pilot”/“bypass” flame, which doesn’t allow enough heat to properly run the boiler and get the
fridge working. This change in flame size goes back and forth about every 2 seconds or so and won’t stay on one or the other for longer than that.
I have removed the fridge and cleaned everything out. The flue, the burner tube, the cooling fins. I used compressed air to clear any sentiment or debris out of all the cracks and crevices.
I figured it might be a pressure regulator issue so, seeing as how the regulator was 14yrs old, I replaced the regulator and pigtails with brand new ones. However, the issues stills remains. The pressure should be fine, seeing as how it is a brand new regulator and pigtails that we’re just installed.
There was a small amount of oil in the outflow, when I removed the old regulator, which I heard isn’t uncommon.
I have a new thermostat on order that will arrive tomorrow. I’ve heard that a fault gas function on the thermostat might cause this issue, but that only what I’ve read.
That’s about it. Like I said before, I am at a total loss for what to do. Last season, the fridge worked perfectly on all functions and the
propane took us through the camping season without issue. Now, the propane isn’t doing anything and that the only one we use when camping since we never use hookup sites.
Anyways, any form of assistance, suggestions or direction would be greatly appreciated. I am fully competent with tools and am not afraid to work with propane. So tell me what I’m missing and What you’d suggest, and I’ll get it done.
Thank you so much in advance!
Cheers!
