Front window blow in! Cover recommendations - Fiberglass RV
Old 08-08-2020, 05:51 PM   #1
Trailer: 1975 13' Boler
Well, I wasnít really expecting this but not surprising in retrospect....first trip with my renovated Boler, including new front window (plexiglass and gasket) and on the way home we look back and discover the front window has blown in. Fortunately there was no damage to anything really! Thereís obviously a lot of pressure at highway speed! Will get hardware to mount a front window cover!! My question is, what have other people done to build a front window cover? Donít want to repeat this experience!!
Shanos is offline   Reply With Quote
Old 08-08-2020, 05:57 PM   #2
Would a piece of 1/4” plexiglass that was big enough to go slightly beyond the gasket be adequate? It’s nice to see through the trailer when driving
Old 08-08-2020, 06:09 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
Try using Lexan instead of plexiglass. MUCH stronger material - it's what the lenses over your tow headlights is made from.
Charlie Y
Old 08-08-2020, 07:21 PM   #4
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
the window should never have blown in. Installed wrong or gasket-ed wrong. I have not read of others having this occur. will others comment about their window blowing in ? many FG RV have no cover. was the window original ? if it was remade too small, it could slide be pushed out of the gasket.
Kenny Strong is offline   Reply With Quote
Old 08-08-2020, 07:27 PM   #5
Utah
I see is was new.
Old 08-08-2020, 07:51 PM   #6
We had a hell of a time replacing our big windows. So. Much. Cussing. I read some people don’t realize there are two steps to the gasket install. The final being squeezing a flap under the other flap. From the outside. I don’t know, but it was awful. If installed properly, I hate to think it could blow in. Yikes.
I have seen the work Shanos has done, top notch. So who knows...
Wash your hands!
ReneeN is offline   Reply With Quote
Old 08-08-2020, 10:27 PM   #7
Hi Kenny, I was thinking that I've seen other Bolers that don't have covers so not necessary to keep the window from blowing in. I did not install the window/gasket. I cut the plexiglass for the window and made it quite a tight fit. It was a one piece gasket installed by a professional shop to avoid the cussing etc that Renee described Not sure what the issue was but I'll be getting in contact with the shop this week.
Old 08-09-2020, 08:40 AM   #8
You are correct. The window should not have blown in if the window was cut correctly and the gasket installed properly.
Iím not an expert, but I did wonder about your statement that you cut it really tight to the opening. Seems to me like there needs to be a small gap for the gasket to fit correctly. Most people just use the old window as a template to cut the new.
Something to discuss with the installer when you take it back.
Old 08-09-2020, 09:10 AM   #9
Hi Jon,
I should clarify that I cut the window to fit tight allowing space that the gasket itself takes up at the edge of the window. The installer said it was a tight fit but the window went in. I'll chat with him this week. The window opening on my trailer was originally quite poorly cut...crooked lines, not level...so I recut the opening and thus couldn't use the old window as a template.
I'll post once I've talked to the installer what the possible cause and solution is.
Old 08-10-2020, 02:44 PM   #10
Installer will be getting back to me but just thought I'd put it out there again and ask if anyone else has had this problem and any further thoughts on the cause
Thanks!
Old 09-15-2020, 07:03 AM   #11
Trailer: ford
mexico
Try the Classic Accessories 80-035-212307-00 RV Windshield Cover. It covers even the largest of windshields.
Natalie21 is offline   Reply With Quote
Old 09-15-2020, 09:20 AM   #12
Thanks!
I think that question was answered already.. twice in fact. Bad installation and /or improper lockstrip / gasket / window size. With a very old window I could see how the gasket might be in such bad shape that it fails under high wind pressure but IMHO a new installation should never blow in unless you are in a tornado.
eco
Propane Tank Cover Can Blow Off Huck Care and Feeding of Molded Fiberglass Trailers 3 05-08-2018 07:49 AM
so...how strong of a wind would it take to blow one of these campers over? lpk49 General Chat 28 05-20-2013 08:43 PM
Spare tire cover - split from trailer windage in a blow rabbit Modifications, Alterations and Updates 5 08-30-2011 12:46 AM
trailer windage in a blow--Will it stay upright? rabbit Care and Feeding of Molded Fiberglass Trailers 17 08-29-2011 12:24 PM
HOW do you blow out your trailer water lines? Karalyn Plumbing | Systems and Fixtures 8 10-16-2006 07:18 PM
