Furnace and other heating options. - Fiberglass RV
Old 08-31-2020, 09:46 AM   #1
Trailer: scamp 13
I am getting a new Scamp 13 in January and I still have time to choose options. I am down to get the furnace, although I have heard it is really loud. (How bad is that?). I am wondering if there are any other realistic safe options (or if I should just learn to live with the noise. it is probably better that being cold...?)
In the past I have used 250 watt, ceramic-type, electric cube heaters (Soleil) and each one gives my about a 10 to 15 degree temperature differential to the outside, but I am not sure how safe they are and also I am often not having access to power anyway.
So I am thinking the furnace is the safe, straightforward way to go. Are there any other, maybe better, options? Thanks!
zack sc is offline   Reply With Quote
Old 08-31-2020, 11:05 AM   #2
ZachO's Avatar
Trailer: Sasquatch
Montana
In my opinion the furnace is the best option, but other people have other opinions. It isn't quiet. It'll wake you up when it comes on at night. I've gotten used it.
You can use a Mr Buddy propane heater or other types like it, so long as you crack a window. To me, this is annoying and sort of scary.
I don't plug in, so some type of propane heater is a must for me, and I like that the installed furnace vents outside so I have less fear of dying in my sleep. I used a Mr Buddy when my furnace went out. It worked, but at least with the small 1# propane canisters, it didn't last the night, so I'd need to put a new canister in at some point during the night.
I was really happy when my furnace was working again.
Old 08-31-2020, 11:29 AM   #3
Compare noise to being cold. I'm picking noise. If the noise really bothers you, turn it off when you go to bed, and restart first thing in the AM. Since 95% of my camping is dry camping, furnace is important.
thrifty bill is online now   Reply With Quote
Old 08-31-2020, 12:24 PM   #4
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
All I can say is EARPLUGS. I sleep with them anyway so that I do not hear various and sundry noises. Yes, the furnace can be loud, but I have only used it twice. One night when camping w/o hookups near Jasper in the Canadian Rockies in early June. The second time I don’t remember where but the trailer was cold and I wanted heat fast. We typically use a 1,000 watt quartz heater with a remote controlled thermostat and it will keep the trailer in the low to mid 70s down when outside temps are hovering around the freezing point. That’s good enough for me because I really don’t want to be out when I have to wear more than a sweat shirt, and even then, I prefer T-shirt weather.
Old 08-31-2020, 05:29 PM   #5
Perryb67's Avatar
Trailer: 2018 Escape 5.0
When without electricity we often use our Martin Catalytic heater. It can go down to about 1200 btu's. Yes, two windows are cracked, but it's much more efficient than any forced air propane furnace, so still uses less fuel. We also have refillable 1# lp tanks. We'd go broke if we had to use those use once/throw away containers.
We also have a Mr Buddy that we bring along in the winter. The Mr Buddy one low is 4,000 btu's, way too hot to run at night. We use it to quickly warm the camper up and also take it to showers to come out of the shower in 70-80 degree heat.
Enjoy,
Perry
2018 Escape 5.0 TA - 2019 Ford F-150, 3.5 V6 Ecoboost,
Previous Eggs - 2001 Scamp 16' Side Bath, 2007 Casita 17' Spirit basic, no bath, water or tanks, that we regret selling, 2003 Bigfoot 25B25RQ, that we also regret selling
Perryb67 is offline   Reply With Quote
Old 08-31-2020, 07:05 PM   #6
Name: Karin & Don
Trailer: 2012 Scamp 13Ft
Maine
Zack, we have a 13 foot Scamp and we like having the heater. Since the 13 foot Scamp is small, it won't take long to heat the trailer. I recommend that you turn it on at night, then have lots of blankets, then turn it off before going to sleep. If it's cold in the morning, then turn it on until the trailer is warm again. Don.
Kardon is online now   Reply With Quote
Old 08-31-2020, 07:23 PM   #7
ZachO's Avatar
Trailer: Sasquatch
Montana
Yep. The way I have my bed set up, I can reach the thermostat from bed. Unless it’s going to be maybe 30 or colder at night, I don’t run the heat. I have a thick down comforter. 10 minutes before I get out of bed, I flip on the thermostat.
But I will run the heat at night if it’s cold enough. The only way with current technology to get this type heater to run quietly is to get a bigger trailer with ducted heat.
Old 08-31-2020, 07:36 PM   #8
A propex furnace would be superior to the Suburban furnace but its not so easy to install. It can be ducted to make it fairly quiet. But I would get the stock furnace. Its inefficient as most vented RV furnaces are, but its also quite safe compared to non-vented alternatives and the best part is that Scamp will install it. Getting a furnace installed after the fact can be a hassle. Just because its there does not mean you have to use it. And of course if you have shore power, the ceramic cube is a non brainer.
Other options include the Buddy Heater, Wave or other catalytic heater, diesel fuel heater, and even a wood stove.. yes.. a wood stove... its been done. All have pros and cons and have been discussed for eons on this site. Seek and ye shall find. (In other words, Google..use search terms and "site: fiberglassrvcom")
Old 08-31-2020, 07:40 PM   #9
I use the heater it keeps me warm and the wife happy i use a cube when we have av power. No heat no wife and i cant sleep with a bunch of covers or in a sleeping bag. Get some recflective truck sun shades over the windows at night to keep insulation from the cold glass. If no heater then save your money and get a tent.
Old 08-31-2020, 07:42 PM   #10
Trailer: 1978 boler
i need input re. my 1978 boler furnace
- the actual heating unit does not turn off when the thermostat clicks off when it has reached the desired temperature
- it burns slightly - although it goes down you can still see a yellow light burning
- the only way to get it to completely go out such that there is only the pilot running is to turn the red dial to pilot.
- is this normal, or is there a small internal leak?
- the unit tests that there is no external leak
HELP
suedolpe is offline   Reply With Quote
Old 09-01-2020, 08:36 AM   #11
ZachO's Avatar
Trailer: Sasquatch
Montana
In terms of electricity and propane use, the RV furnaces aren’t “efficient”. But in terms of how well they heat the space, they’re amazing.
It’s like a giant, old inefficient V8 gas engine. It’s not efficient, but touch the gas pedal and it GOES. The furnace is old tech and doesn’t use propane or battery all that efficiently. But turn it on and your little scamp is going to be roasty, fast.
Old 09-01-2020, 12:09 PM   #12
Trailer: scamp 13
Thanks a lot everyone. I think I will get the furnace. I am also planning to get the group 27 battery option and the dual propane tanks, so that should maybe make the inefficiency a bit less of a problem.
Old 09-05-2020, 01:19 PM   #13
Trailer: scamp
Indiana
It has some noise. Not that much and my very old one works fine even in very cold weather
computerspook is offline   Reply With Quote
Old 09-10-2020, 08:51 PM   #14
Trailer: Scamp 16'
I'm confused. I was recently told that the furnace won't work without shore power (120V) because it needs it for the fan. But from reading some of these posts, it seems like some of you are saying that you use the furnace when you have no hook-ups.
Is it able to run with just propane? Or just propane and 12V battery?
I'm going camping in 2 weeks and will need it (northern Ontario).
I have a 2001 Scamp 16' and haven't tried the furnace yet.
(Please tell me I don't need shore power!)
Thanks!
Scamper Linda is offline   Reply With Quote
Old 09-10-2020, 09:21 PM   #15
Trailer: Scamp 13'
Thanks!
You don't need shore power
chrisblessing is offline   Reply With Quote
Old 09-10-2020, 10:00 PM   #16
Trailer: scamp
Indiana
Thanks!
You don't need shore power. But test it before you go. Make sure it lights and etc. It runs on 12 volts. But if the igniter is not working it will suck the battery dry in a few hours of failing to light.
Old 09-11-2020, 06:27 AM   #17
And old gravity style furnaces that you see in some 1970s trailers used no electricity
Old 09-13-2020, 09:25 PM   #18
JFA
Trailer: boler
boler heater
HELP
I had a similar issue with my boler heater. A friend who is a gas technician checked it out and advised me that the control unit was no good. The heater is old enough that parts are not available.
The pilot light will work without the control unit. Maybe that's the yellow light you see?
You can heat up the boler then turn down and get some heat from the pilot.
Either get by by bundling up in bed, or buy a Mr Buddy catalytic heater as I did.
If you're concerned about leaks, suggest you have an RV tech test the junctions, or do it yourself with a little soapy water.
JFA is offline   Reply With Quote
Old 09-14-2020, 07:59 AM   #19
Trailer: scamp
Indiana
HELP
Sure sounds like something going wrong. Might look up the manual for your unit. (Furnace not camper) that should tell you. But that sure is not how any that I know of work. Definitely need to trace this down. Now on mine the flame runs for about 30 seconds after the thermostat turns off then the fan runs for a couple minutes. But what you are describing sure sounds like an unsafe condition.
Old 09-20-2020, 09:58 PM   #20
Everywhere
Thanks!
The furnace blower runs off the 12V battery. It can be a bit hungry, though. Running full blast it'll empty the battery in under a day. Realistically it won't run anywhere close to constantly unless it's really cold, but it'll still eat into your power a decent bit.
furnace
Furnace pilot light shuts off after heating? markjeff Problem Solving | Owners Helping Owners 6 11-08-2016 03:44 PM
Utilities and other options BASE1360 Problem Solving | Owners Helping Owners 6 08-19-2015 07:25 PM
Options, Options Options Tezha Problem Solving | Owners Helping Owners 8 09-19-2010 11:55 AM
Furnace not heating Horst K. Problem Solving | Owners Helping Owners 12 05-02-2010 09:27 PM
Furnace heating up upper drawer and fridge Steve Smith Problem Solving | Owners Helping Owners 6 02-26-2010 04:25 PM
