Furnace Atwood HF 8012 - Fiberglass RV
Old 02-15-2025, 09:44 PM   #1
Dax
Trailer: Havasu
So I'm stumped. I recently changed the motor and it's been working great. Then today it just suddenly stopped making heat.
The pilot light is on. The motor is blowing, but it won't increase the fire outside of pilot level.
I checked the gas. It's full, no leaks on the line. Other gas appliances work fine.
Anyone know what else I can check? It's cold and I don't want to cut my trip short
This is version 1, not 2
Dax is offline   Reply With Quote
Old 02-25-2025, 09:49 PM   #2
Trailer: Burro
Just like you gas furnace or gas cook stove in your home, you might need a new thermal coupler. The thing that sticks up by your pilot light.. or… you can try to take a torch or a long light and heat that thing up ( also cleans it off) . And see if that works. Worked both on my 50’s cookstove and my wall heater. Good luck. Just got a Burro 1986. Major fixer upper. Haven’t got to the heater yet.
Debbieo is offline   Reply With Quote
Old 03-01-2025, 01:25 PM   #3
Trailer: 1979 Layton 22 ft / 2004 Ram-Cummins 2500 2wd
Just a thought: I believe the 'thermo-couple' controls all gas flow, including the pilot, so it should be ok.I'm not sure how the main burner supply is controlled, but think it is fed via a solenoid valve (possibly 12V but more likely from the Thermocouple) with the circuit guarded by a 'High Limit' switch.
If your fan was failing, the high limit switch may have tripped and need resetting .
Note: I'm not familiar with your particular furnace but this is the concept with household gas furnaces: If you lose power (for fan) and there is a call for heat, the main burner will light, overheat the system, trip the 'safety', and prevent fire. But, the 'pilot' will stay on.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
Old 03-01-2025, 08:36 PM   #4
Trailer: scamp
Indiana
It sounds like time for a professional. To easy to have something bad happen when working with gas and not knowing what you are doing.
computerspook is offline   Reply With Quote
Old 03-01-2025, 11:54 PM   #5
Trailer: Bigfoot 25 RQ
Ohio
Three things it could be, sail switch, high limit switch, bad solenoid in the gas valve and or the thermocouple. Also the main board. Well that’s 5 .
oldwave is offline   Reply With Quote
furnace
HELP Atwood 8012 Furnace 56mercman Problem Solving | Owners Helping Owners 6 05-27-2019 06:53 AM
Heeelp!! Trying to shoehorn Atwood 8012 Heater into 13' Trill trilliumdon Problem Solving | Owners Helping Owners 1 04-23-2011 09:53 AM
