Gasket for small crank window in Boler door - Fiberglass RV
RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-03-2020, 02:21 PM   #1
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
I have a 1979 boler 13 footer. I'm trying to remove and reseal the small crank window in the door. Does anyone know how to remove the rubber gasket going around the bottom and two sides of the window frame? Do you know where I can get a new gasket? Does anyone know what the window is called? Any help would be greatly appreciated. I tried using the google search of the site but can't get it to work.
Old 05-03-2020, 05:47 PM   #2
If yours is like mine the gasket folds over the over the frame and rivets go through the frame and the gasket to secure it.
Here's some pics of what I have. Don't know if yours is the same style of crank out jalousie
But I got my replacement gasket material from vintagetrailergaskets.com. Really helpful and good to deal with.
Hope this helps.
Bob
bobdobqb is offline   Reply With Quote
Old 05-04-2020, 09:49 AM   #3
Alex Adams's Avatar
New Hampshire
Did you do anything special to install it? I assume you have to make holes for the rivets to pass through but I am looking for any other steps.
Old 05-04-2020, 10:01 AM   #4
The only thing I did other than punch through for the rivet holes (I just used an awl) was to cut the seal in a V at the corners and then once I had the seal all fitted in place around the frame used some RTV sealant on the back side where the V joined. Probably didn't need to do that but better safe than sorry I thought.
All in all pretty straight forward.
Old 05-04-2020, 10:08 AM   #5
Alex Adams's Avatar
New Hampshire
Great! Thank you very much!
Old 05-04-2020, 10:13 AM   #6
Glad I could help! Also just fyi when I did mine I needed to fix up the crank assembly and got the parts from vintagetrailersupply.com They had all the other bits I needed.
boler
Small Hehr Crank Window Screen Cmtravels Problem Solving | Owners Helping Owners 5 03-25-2015 07:22 AM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
SOLD - Small Crank Window Nakita B Classified Archives 2 06-16-2008 11:12 AM
Crank'n'go solar/crank am/fm radio Legacy Posts General Chat 12 09-03-2006 11:12 AM
