glass fell out of kitchen crankup window - Fiberglass RV
Old 05-29-2024, 01:48 PM   #1
CO
Smile glass fell out of kitchen crankup window
While cleaning the small crank out window above the stove in our 13 ft scamp the glass fell out. The nylon rollers of the crank out mechanism are disintegrated. The window itself is in good shape as is the frame around it. However, the entire assembly just dropped out. The window has a railing at the top that is bent over as if to click onto a railing inside the frame on the trailer. I tried to push the glass assembly up into the trailer window frame thinking it would 'click' into place. I probably need to enlist the help of a younger stronger person to do that :-) Please see the pictures I uploaded to help clarify what I'm trying to describe.
Does the glass/frame simply slide up into the camper window frame and 'click' into place or do I need to disassemble the window? I think I've located the crank/torque mechanism that I need.
Thank you for any help and insights you may have.
ldhendrickson is offline   Reply With Quote
Old 06-17-2024, 02:31 PM   #2
CO
removed window frame, slid,tapped glass into frame, replaced crank mechanism, reinstalled window with butyl tape.
Surfside hinge pin fell out! Happy Vongole Problem Solving | Owners Helping Owners 2 06-20-2021 10:03 PM
Kitchen or no kitchen? AJCmedia Modifications, Alterations and Updates 44 04-02-2016 03:25 PM
Potable fresh water tank spigot fell off brendaross Problem Solving | Owners Helping Owners 1 09-18-2007 05:13 PM
