Have a replacement steel tank but it is not ready. Repairing the original tank till steel tank is ready. Tank patches started. Really bad shape will not last long but will get us through our camping till replacement tank can be made ready.
From door side:
Original
boler tank has 3 connections
- Low 1/2" high threaded hole tight into the far top left corner, threaded for sink drain abs to screw into from inside trailer. Steel tank connection is close to this location. Will remove pipes and see if I can make it work or change it.
- No Hole for shower Top left side corner of tank again flush screw connection for shower drain. Needs to be added to new tank.
- The steel tank has drain in a spot that will work with some changes to the abs drain alignment.
Steel tank will not install as is would have to make a much larger hole slot hole to fit and no shower connection so changes first then install.
Till the steel tank is ready will use the repaired plastic tank. It is not going to last long though deterioration of the material it is made of is to great.
While original tank is out will measure location of holes on it for changes to the steel tank.
The drain pipes at side can be crumbled with my hand. Have new 3" flange for screwing into the toilet black water tank base, 90 degree elbow, 3" flange, and gate shut off, 3x3x1.5 Y pipe will be in today and small 1.5" shut off flange to tank drain. Will install after tank is back in place.
