Heater HELP Boler 1700 - Fiberglass RV
Old 04-21-2021, 12:17 PM   #1
Hey friends, I have been restoring my 1700 over the winter and I am down to the short strokes on the inside. Last night I filled up the water tank to test the pump and all of the connections. Everything works like a charm EXCEPT I have a leak coming from a valve on the outside of the hot water tank (see photo). When I attempted to tighten the valve it just appears to spin in place. Anyone have a similar issue? If so, did you find a fix?
TBlevins is offline   Reply With Quote
Old 04-21-2021, 01:34 PM   #2
AC0GV's Avatar
Wisconsin
Drain plug?
Valve or drain plug. If it is just the drain plug, remove it clean the threads in the tank with a pick or brush and replace the plug with a new one using thread sealant. (Use plastic or brass, steel will rust in.)
Check size before ordering. https://smile.amazon.com/Camco-Water...9033535&sr=8-6
Old 04-21-2021, 02:22 PM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Thatís a hose bib plug, wrong threads. You need to get a npt plug.
mszabo is online now   Reply With Quote
Old 04-21-2021, 03:12 PM   #4
Thanks AC0GV! Just for clarification, when you say remove it, you are referring to the plastic (male) piece in the centre, not the metal female portion?
Old 04-21-2021, 03:17 PM   #5
AC0GV's Avatar
Wisconsin
Yes
it sounds like you have the wrong plug. Many places will stock the half inch National Pipe Thread plastic plug. Note that I have never owned a Boler.
Old 04-21-2021, 03:19 PM   #6
Thanks! I'll give that a go. they stock them at my local Canadian Tire.
Old 04-22-2021, 08:36 AM   #7
An update: the NPT plug was actually way too small. turns out the threats ARE actually a 3/4 garden hose thread. I also learned that the metal part that appeared to just seen in place actually tightens up, which stopped the leak entirely. Who knew?
Old 04-22-2021, 12:23 PM   #8
AC0GV's Avatar
Wisconsin
Modification
SOme one has made a modification to your water heater.
boler
HELP! New Boler 1700-78 Owners Lucy.Muskoka Hi, I am.... 7 11-11-2020 07:30 AM
Boler 1700 refresh. Herb P Modifications, Alterations and Updates 72 09-24-2012 07:57 AM
Water Heater Boler 1700 Rene Care and Feeding of Molded Fiberglass Trailers 9 08-08-2011 01:46 PM
Boler 1700 range hood Peggy Problem Solving | Owners Helping Owners 2 04-23-2008 05:09 PM
boler 1700 tank capacities. Herb P Plumbing | Systems and Fixtures 7 07-22-2007 04:35 PM
