Help identifying Window trim - Fiberglass RV
Old 09-21-2020, 07:47 PM   #1
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Exclamation Help identifying Window trim
I have a 1979 Boler 13 footer with a sliding rear window. I have two pieces of trim that I am trying to find. I am really hoping the super sleuths here can ID these.
Here is a picture of the window frame with nothing in place. The bottom goes towards the outside and the top goes toward the trailer interior. There are three grooves in the frame. The bottom one is for the first piece of trim I am trying to ID. The second groove in the middle is for the felt sliding window track. The third groove is for a piece of soft plastic trim that I am trying to ID:
Here is what the end of the rubber piece looks like:
The dimensions are approximately 11/16 inch wide at the top, the bulb is about 1/4 inch wide and fits a 3/8 inch deep channel. The tongue part partially covers the felt sliding window track but doesn't quite reach the window itself:
Finally, here is the flexible plastic trim. It goes all the way around the frame in the outer groove closest to the interior of the trailer. It is flat with two splines coming off of it. The wide part measures about 3/8 inch and the splines are i/4 inch deep.
Here is the end of the piece:
Here is the bottom of the piece showing the two splines:
Any help identifying would be appreciated. I will be extremely grateful if someone could tell me where I can buy these! Thanks for the assistance.
Old 09-21-2020, 10:18 PM   #2
Alex Adams's Avatar
New Hampshire
Here are shots of the entire window.
This is the outside:
Here is the inside:
Old 09-22-2020, 09:53 PM   #3
Trailer: Bounder 36 ft
Cobourg
Rubber for windows
Here in Ontario and I am sure you have the same, RV stores that have on line catalogues where they have a rubber section. Also check rv scrap sites. They may be able to help you.
Steven r is offline   Reply With Quote
Old 09-23-2020, 06:12 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Hello Alex,
It would help in tracking down the trim if you could determine the brand, series and/or model info. On the Hehr sliding windows on our Boler 17, this info is stamped on the outside edge that's not visible when the window is installed. We did eventually purchase seals for those windows.
John
Old 09-23-2020, 06:21 AM   #5
Alex Adams's Avatar
New Hampshire
John, there are no marks what so ever stamped on the window. I couldn't find anything like it shown on Vintage Trailer Gaskets site for any of the brands they have pictures for and am communicating with Robert to see what they can do for me. I've looked across the internet with no luck so far. I was hoping one of the Boler gurus here could inform me but no replies yet.
Old 09-23-2020, 06:33 AM   #6
Alex, the trim with the bulb in your second and third pics could be this item at Pelland Enterprises:
Pelland Enterprises Motor Home Products - Pelland Enterprises
It is Hehr part number 009-057 aka H009-057. You can also google this part number and see that several other companies sell it.
For our windows, we figured out several part numbers that appeared to be likely candidates and then contacted three companies (Pelland, All-Rite, Vintage Trailer Gaskets) for samples to check fit.
John
Old 09-23-2020, 06:38 AM   #7
Here is another pic of Hehr 009-057:
https://interstatervmetalandsupply.com/products/009-057
Old 09-23-2020, 07:59 AM   #8
Alex Adams's Avatar
New Hampshire
John, that is close but the top of mine is flat without the extra material on top and the bulb doesn't extend as far.
Help Request - Identifying window type J.S. Warwick General Chat 1 06-18-2020 01:10 PM
Identifying Scamp Window Leaks kdhanso Care and Feeding of Molded Fiberglass Trailers 5 10-12-2013 01:18 PM
Need Help Identifying this Fiberglass Travel Trailer Joe Balla General Chat 33 03-29-2010 09:18 AM
Need help in Identifying ? Don N Care and Feeding of Molded Fiberglass Trailers 3 12-15-2008 08:16 AM
