03-27-2021, 11:08 PM
Trailer: Scamp 13'
Help Pricing a Scamp to Sell
Hi Everyone-
I am selling my Scamp and would appreciate some feedback about how much I should ask. I'm located in Northern California. I have attached below the advertisement: Sorry- It's long and detailed.
I bought this Scamp 13 trailer in September 2020, and intended to work on it as a project. I purchased most of the necessary parts I needed to complete the work, and then became overwhelmed with a new job. So, I decided to go a different direction and purchase a new one from the Scamp factory.
This is a 2000 13ft Scamp trailer. These highly sought-after lightweight fiberglass trailers can be towed by most passenger cars. This trailer is structurally sound with a reinforced bottom and brand new wheels, tires and jack. The interior of this trailer has been gutted with partial installation of a wood closet, wood front bench and oak flooring (all unfinished).
The exterior has a number of rivet and other small holes that have been filled, but need to be sanded and painted over. The front door needs to be re-hung and the window replaced (all parts included).
This Scamp comes with a clear title and all newly purchased parts and is wired for towing.
This includes the following:
Exterior:
Entry lock with keys
Stabilizers
Wheel Chocks
Single Metal Step
Safety Chains
Wheels and Tires (installed)
Bottom Door Slide
Rib Door Seal
Side Windows (2 installed)
31 ft Black Plastic Trim
Jack with spare wheel
Red and Amber Marker Lights
Cover
Interior
Oak Floor Boards (New in sealed box)
Tan Headliner
Headliner fabric strips
MWS 24 x 100 Double Bubble Reflective Foil Insulation Thermal Barrier
2 cans spray adhesive
Putty Tape Seal
LED Double Dome Light
Interior LED bulbs
Electrical System
12 Volt USB port
12 Volt Charging Station
Battery Disconnect w/ key
Cord Port
30 to 15 Amp Adapter
Fuse Kit
Battery Box with strap
Inline fuse holder
Junction Box 7-way
30 Amp Shore Power Pigtail
Double Rocker Switch
Wiring Terminal Kit
Converter
Gas System
LP Tank Hold Down Strap
LP Regulator to Trailer Hose
Single Propane Gas Gauge
36 LP Supply Hose
Single Propane Tank Regulator
Water System
Fresh Water Filter with Barb
Fresh Water Filler Hose
Blue Pex Water Line
Fresh Water Tank
City Water Connection
Hose Carrier End Cap
Fresh Water Filter
Petcock Drain Valve
Fresh Water Filler
Valterra Hand Pump Faucet
Camco Flexible Camper Drain Tap w/ Hose system for RVs and Trailers
Galley Items
Dometic Two-Stove Cooktop
ZUHNE 15 x 15 drop in stainless steel sink
3-Way Refrigerator (used- in good shape)
Microwave with Pizza Oven
Window (uninstalled)
20 Fridge Vent (uninstalled)
03-28-2021, 06:59 AM
Am I understanding you do not have any of the original fiberglass interior benches and cabinets? Do you have a window for every opening? Does the door fit correctly in the opening (ie, were there any significant gaps before it was removed)? You built a door closet and front bench, but you haven’t installed the Reflectix or marine headliner (so bare fiberglass walls)? What do you mean by "reinforced bottom"?
Pictures showing the condition of the shell, the parts, and the work already done (especially the cabinets you built) would be very helpful. Wild guess, $2-4K. You could certainly try for more in this current overheated market. You might get lucky, but realistically, a sensible person would realize this project has a ton of work remaining. A skilled cabinetmaker working full time might have it ready to camp before this season is over. For most people it will be a year’s worth of weekends.
I would encourage you to modify the statement “can be towed with most passenger vehicles." No-bath 13' Scamps end up weighing 1400-1800# loaded for camping, but sedans are generally tow-rated for 1000# or less. Even many popular compact SUVs like the CR-V and RAV4 are rated 1500#, which is marginal. I usually recommend a minimum tow rating of 2000# for a 13’ molded trailer, which narrows the list quite a bit.
03-28-2021, 07:19 AM
Without pictures, no idea. Pictures sell trailers. Buyers don't pay attention to text.
Uncompleted project = hefty discount. I would not expect to recoup $$ spent, particularly on a recent purchase, unless the original purchase was a smoking hot deal. Did it originally have a fiberglass interior?
Partially finished projects can sell for less than projects not started, as there are people looking for a blank slate to build their dream trailer. The quality of the work so far is going to be important, rather than a parts list. The choice is clear, put enough work into it so it is road worthy: windows and doors installed, outside lights work, enough structure inside that is not a blob of jello going down the road; or just heavily discount it and move on. Sometimes the latter is the best choice.
I have been there on projects, where I am just "sick and tired" of it. Come get it out of my yard!
There are definitely buyers out there for projects at the appropriate price.
03-28-2021, 09:44 AM
Trailer: 2014 Scamp 16, 2011 RAV4 V6
I understand where youre at. I bought a 1973 Compact II via Craigslist for $900. After gutting it, starting a frame-off restoration, painting it, etc, I realized how big a project it was. My wife did too and ordered a new Scamp. I sold the unfinished project for $2,000, which was less than I had into it. How you price it is at least partially dependent on how quickly you want to sell it. I was just happy to see mine go to an appreciative buyer who had plans for it (a mobile photography darkroom) and ultimately completed it. Weve never looked back.
03-28-2021, 10:48 AM
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
Where in Cali are you located? I might be interested in another project if the price is right. Send me a message shammel@hotmail.com
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe.
03-28-2021, 12:23 PM
Trailer: Scamp 13'
Pictures of 2000 Scamp via Slideshow
https://youtu.be/bS2TMFseRP0
I found a way to add pictures- Via slideshow on YouTube- If you can't access, please let me know- Thanks for your feedback all.
03-28-2021, 12:25 PM
Trailer: Scamp 13'
Originally Posted by Jon in AZ
Am I understanding you do not have any of the original fiberglass interior benches and cabinets? Do you have a window for every opening? Does the door fit correctly in the opening (ie, were there any significant gaps before it was removed)? You built a door closet and front bench, but you havent installed the Reflectix or marine headliner (so bare fiberglass walls)? What do you mean by "reinforced bottom"?
Pictures showing the condition of the shell, the parts, and the work already done (especially the cabinets you built) would be very helpful. Wild guess, $2-4K. You could certainly try for more in this current overheated market. You might get lucky, but realistically, a sensible person would realize this project has a ton of work remaining. A skilled cabinetmaker working full time might have it ready to camp before this season is over. For most people it will be a years worth of weekends.
I would encourage you to modify the statement can be towed with most passenger vehicles." No-bath 13' Scamps end up weighing 1400-1800# loaded for camping, but sedans are generally tow-rated for 1000# or less. Even many popular compact SUVs like the CR-V and RAV4 are rated 1500#, which is marginal. I usually recommend a minimum tow rating of 2000# for a 13 molded trailer, which narrows the list quite a bit.
Here is a link to my pictures:
03-28-2021, 12:26 PM
Trailer: Scamp 13'
Here is a link to the pictures-
03-28-2021, 12:28 PM
Trailer: Scamp 13'
Originally Posted by LaDonnaCurry
Hi Everyone-
Exterior:
Stabilizers
Wheel Chocks
Single Metal Step
Safety Chains
Bottom Door Slide
Rib Door Seal
Cover
Interior
Tan Headliner
Putty Tape Seal
Interior LED bulbs
Electrical System
12 Volt USB port
Cord Port
Fuse Kit
Inline fuse holder
Junction Box 7-way
Wiring Terminal Kit
Converter
Gas System
36 LP Supply Hose
Water System
Blue Pex Water Line
Fresh Water Tank
Fresh Water Filter
Petcock Drain Valve
Fresh Water Filler
Galley Items
Link to my slideshow on YouTube
Trailer: Scamp 13'
Hi Steve-
I am located in the San Francisco Bay Area-
03-28-2021, 12:30 PM
Trailer: Scamp 13'
Thank-you for this feedback! I agree that I should be more specific about the types of vehicles that can tow this.
